One of the best things that I found to use was a water filtration system that you can buy at most any home improvement warehouse. I have built several units. I have one on my 1995 Dodge ram 4X4 truck and I have built several others for friends.MadeInJapan wrote:Thanks for sharing!
How much of this do you think can be built on your own rather than buy a kit that's almost $300 ?
I went to a local scrap yard and bought some small sheets of stainless steel for the electrodes and I cut them to fit in practically any size water filter unit. I do have them running into a secondary bubbler as a safety and just to see it work. The biggest safety feature needed is a "One way valve" on the exit side of your system prior to the entry of the intake. This is needed in case you may have some kind of backfire or other engine problem...because beleive me, you do NOT want the fire to get back to the bubbler or to the fuel cell. I had that happen in my very first trial...I was lucky, it was only a smal explosion.
You will definitely have to manipulate the computer to trick it into thinking that the fuel mix is correct. I have a single wire O2 sensor (the easiest). I measured the resistance of the meter during normal operating condition after fully warmed up. I added a resistor loop to ground that told my computer it was reading the same thing all of the time. You can buy pre-made units for practically any type of O2 sensor that you can adjust using a dial to get it to meet your cars best needs.
I installed the unit with am amp meter so I could monitor the draw on the system and I regularly pull 15 amps.
My unit makes 2 liters of hydrogen gas in 32 seconds after it has warmed up.
My Dodge truck got 17 mpg with a 318 cu.in. V8 with a tuned port EFI from the factory. After installing and before manipulating the O2 sensor, I got 14 mpg...My computer thought I was running lean and it dumped in more gas.
After tricking the computer into thinking it was reading a roughly aconstant 14% O2, the mpg went up to 29 mpg and the performance is way better than factory. The engine does run hotter than factory...it is one side note that most people will not mention...I had a easy fix on my truck, the factory thermostat is a 210 degree unit, I put in a 190 degree and drilled a 1/4" hole in the edge of it to slightly increase water flow. Now it runs at a constant 215 degrees where it has always ran at 210 every since it was new. I don't think 5 degrees with hurt anything.
This truck had 135k miles on it when I put the unit on and it has been running the hydrogen cell since September 2008. I like it and so does my wallet.
