BTW, this "pre_load" is only applied to the bushings not the ball-joint, here I quote the procedure from Volvo:
"...Using NEW bolts and nuts, install control arm to subframe.
Do not tighten bolts and nuts at this time. Using NEW nuts,
install ball joints. Tighten nuts to 13 ft. lbs. (18 N.m), then
tighten an additional 120 degrees. Tighten inside nut first and work
outward. Lower vehicle and bounce a few times. Tighten control arm
nuts in sub-frame to 48 ft. lbs. (65 N.m), then tighten an additional
120 degrees."
Ball joint/control arm survey
Ball Joint / Control Arm Survey
confused_al
- Year and Model: 1996 TLA wagon
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
- RobTheModd
- Year and Model: 98 S70T5M
- Has thanked: 5 times
- Been thanked: 7 times
Weird.
I was always told you could tighten up the ones on the frame all the way, but to make sure the ball joint gets done like that (load.) before you tighten it down all the way.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I just called a Volvo dealer and they said they can still get the arms with the replaceable ball joint. They wasn't sure if the arm would fit my T-5R wagon. Does anyone know for sure?
- 4751 Views
Last post by oragex
- 15 Replies
- 3758 Views
- 4212 Views
Last post by Tonyx
- 12 Replies
- 5659 Views
Last post by darrylrobert
- 7207 Views
Last post by BrianV70
