Brake failure message came on as well as the ABS light
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Has thanked: 1505 times
Been thanked: 3817 times
Re: Brake failure message came on as well as the ABS light
DC resistance is something like 1000 ohms but I've found variation of 50-75% on working sensors
No codes probably means the ABS UNIT HAS pooched..a bad sensor or wire will definitely code
oilspot
Year and Model: 99 V70XC
Post by oilspot »
Following this topic with great interest as I just bought a cheap 2004 xc70 with same issue (among other things) frozen odometer, brake failure warning in display, abs light on. Seller said awd was malfunctioning so his mechanic "unhooked something" but all the fuses appear to be in place.
