Sunroof Won't Open After Battery Was Disconnected??
Disconnected Battery, Now Sunroof Won't Open
My sunroof has been half open for about two weeks now and I was excited to read the very first part of beetlebobs post.
So I just tried the lock/unlock 5 times and open the door with the key in. Gave me the alarm service message but it worked like a charm! My sunroof is finally closed!
"Nice" I said to myself. Ok what else...This happens to me every time I do a battery. SO I will tell you all how to get it to work.
ffs... my driver side window is stuck in the up position. Anyway, I figured to disconnect the battery. I did that and the bloody car told me the alarm system needed servicing. Ah bugger...Roll down drivers window and close door
hey! thanks for the help here (just a clueless, experienced mecanic and a passing reader)
what worked for my 2009 Volvo S60 was the battery cable procedure posted by VCA, the Beetlebob trick did not work.
regardless, I'm happy I found a quick answer to my problem, so I actually bothered to sign up and post a thank you memo.
Who knows what else it solved on the car that I was not aware of yet!!
aaronlife
- Year and Model: 2010 Volvo XC60
- Has thanked: 1 time
- Been thanked: 2 times
I just wanted to second the solution that was suggested by VCA disconnect the positive and negative terminals on the battery, put the ignition in position two with the key, reconnect the negative terminal, reconnect the positive terminal… put everything back together. Takes a couple minutes. SRS light was out on my dashboard by the time I got in the car and the sunroof worked.
My sunroof failed after I disconnected the negative terminal on the battery for about a week while I had my dashboard odometer display repaired. The alarm trick did not work and my siren does not sound even though lights flash and the DIM shows alarm was activated. The door reset did not work either.
Thanks.
Thanks.
- 814 Views
Last post by beigg
- 25 Replies
- 13665 Views
Last post by wizechatmgr
- 715 Views
Last post by twiggs462
- 1136 Views
Last post by racertim
- 1813 Views
Last post by IslandV70
