P80 MASTER STUCK OIL FILTER CANISTER THREAD Topic is solved
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
FireFox31 wrote: 11 May 2024, 18:21
mrtinker wrote: 08 May 2024, 11:50 I have a stubborn oil filter, an insert type filter with the stupid plastic housing that I can't get a good grip on.
I agree with jmartin and use the CTA 2489. It grabs the 1999-2000 plastic filter cover perfectly (unless the cover is banged up). For reinstallation, I can put my torque wrench on it and tighten it to spec (written on the plastic cover, I believe). Yes it's bulky, but I store it nestled inside my CTA oil funnel which I also recommend.
I did finally use the Craftsman metal filter remover linked above, but on a pickup truck. It took a little getting used to but it worked. Still have to try it on my 1998 whose filter has been on for seven years now.
Seven years? Say it ain't so! Moose abuse will lead to a Moose attack leaving you stranded and the worst for wear :shock:?
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
MoVolvos wrote: 11 May 2024, 19:49
FireFox31 wrote: 11 May 2024, 18:21Still have to try it on my 1998 whose filter has been on for seven years now.
The car has driven maybe 1500 miles in that time; 1400 miles and six years under previous ownership, 100 miles and one year under mine. I'll get to it someday, it's patiently waiting.
FireFox31
Has thanked: 1611 times
Been thanked: 4072 times
Is the 1998 T5 the plastic/ insert type or the metal can, Firefox?
I’ve found the metal cans rust in a few years in Salt country. I’ve had two blow out on top with Mann filters
MoVolvos
Post by MoVolvos »
FireFox31 wrote: 11 May 2024, 20:08
I see, hope it's someday soon rather than some year :D.
FireFox31
Post by FireFox31 »
abscate wrote: 12 May 2024, 07:37 Is the 1998 T5 the plastic/ insert type or the metal can, Firefox?
The 1998 T5 is the metal can. Let's hope I can remove it. Are any 1998's not the metal can?
FireFox31
mrtinker
Year and Model: V70 XC
Post by mrtinker »
mrtinker wrote: 08 May 2024, 11:50 I have a stubborn oil filter, an insert type filter with the stupid plastic housing that I can't get a good grip on...
A followup & appreciation: the plastic filter housing successfully removed.
Seems like the trick this time was cleaning the oil and grime off the filter housing with some iso alcohol and then using a slightly longer and sturdier oil filter band-type tool borrowed from local mechanic with a rag wrapped around the filter to improve grip.
The longer handle on the tool was key to applying leverage accurately. Also props to my pops for finding the right tool.
-Other attempts included buying a filter wrench(local store didn't have my size), hose clamp and hammer (not enough room to swing), cursing and taking a nap (mentally useful)
Thanks for all the ideas, I also bought the appropriate filter wrench for future oil changes
-'99 Blue V70 XC
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
mrtinker wrote: 24 May 2024, 13:39
It was so much work you fell down in the grass (but managed to take a photo with your last bit of strength). Thanks for your tips.
Also -> Amazon link
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
... some iso alcohol ...
Some apply alcohol earlier in the process...
