Jim, I picked these up at O'Reilly's. I believe this is the size because I was thinking of tubing I.D. instead of the actual O.D size of the fitting.
http://www.oreillyauto.com/site/c/detai ... &ppt=N1171
I also recall cutting the barb off the larger end to make it short enough to work in the limited space, but a small worm screw hose clamp will secure it to the fuel line connector to the manifold.
1996 850 GLT Need to find vacuum leak >> found
