Hello,
After some research, this fuel pressure regulator appears to be very similar to 960's, 760's one:
BOSCH 0 280 160 294
I guess that it will fit in the fuel line.
2000 V70R - AWD Fuel pump and ejector (Fuel pump 9470674)
Maestrours
- Year and Model: 03/2000 V70 XC 2.4T
- Has thanked: 29 times
- Been thanked: 9 times
rrres
- Year and Model: 1999 v70XC
- Has thanked: 12 times
- Been thanked: 34 times
Just an idea: can you disconnect the crossover fuel line on the RHS fuel pump (have a pan or bottle to catch the fuel) and then activate the pump by jumping the relay? It will not be an actual pressure measurement but you should see if you're getting a good flow. If you're not getting good flow, then work your way upstream. Again, just an idea.Maestrours wrote: 11 Sep 2023, 00:30 -How would you test the correct functionning of the left-to right fuel tank system ?
It's blowby
Maestrours
Hi, and thanks for the idea.
I think that, if I do that, I'll have no fuel return, as the left side's retuen fuel is used to pump more and more fuel from this side.
If I take my fuel tank down again i'll try...
- 39 Replies
- 2983 Views
Last post by VolvoOwl98
- 15 Replies
- 2387 Views
Last post by foggydogg
- 11 Replies
- 3669 Views
- 115 Replies
- 15072 Views
- 185 Views
Last post by PatternFlyer
