98 V70xc - Accidentally put in 10 quarts of oil and drove
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
ViktorNova wrote:... Temperature stayed in the normal range and heat blew hot, but there seemed to be abnormally high coolant pressure - when I parked the reservoir cap was hissing and radiator inlet hose was noticeably less squishy than normal. ...
So other than running a compression test and changing the oil filter, what should I do now? ...
Is there any oil in the coolant?
You can rationalize the firm hoses but that hissing is not normal, worth following up on. I would check the coolant for exhaust gases too, just to cover all the bases on the blown-head-gasket front.
Ou2mame
Year and Model: 2004 xc90
Post by Ou2mame »
Yeah that's what I was thinking. Subarus are known to dump exhaust into the coolant system and the first sign is an over pressurized coolant hose.
