E-brake doesn't work...
This topic is in the MVS Volvo Repair Database » How To Replace Volvo E-Brake Pads
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
Not trying to derail
If one has a non op e-brake system on an automatic, and the brakes go out (descending from the rockies), can I shift into 3rd, then 1st? Or is my only choice to use the side barrier to slow down (or coast out if possible).
My problem is the entire cable snapped because the drum seized. All the e brake hard wear and cables are now missing (had to be taken out for car to drive).
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
Has thanked: 1613 times
Been thanked: 4075 times
You can engine brake an automatic just like a standard it will help slow you down.
Complete brake failure on cars is really rare thanks to dual brake circuits. If you maintain them at all, you can drive for your lifetime without experiencing brake failure.
mika
Post by mika »
well that is re assuring. I hard an elaborate plan of wearing a helmet and jumping out if anything 8)
'97 855 N/A
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
abscate wrote: Both of my bricks are manuals so working e-brakes are mandatory
Yes, mine just became a manual so I figured some R&R on the parking brake was due.
polskamafia mjl
NAPA shoes fit like a glove although I did have to grind away the lip on the inside of the driver side rotor. I'm not sure how the expander mechanism works but I couldn't get it to compress which made it difficult to slide the rotor on. The passenger side with the working cable was easy and and everything fit correctly. I'll be sending the other ones back to FCP. Now I just need to get motivated to replace the broken e brake cable.
JeanPete
Year and Model: '96 855R
Post by JeanPete »
Hello,
abscate wrote:Nope - you adjust the star wheels first to get the shoes close to the drum without binding. A little bit of scraping and noise is ok - they need to be close to the drum to be effective.
Is it normal, please? (got to click on pix to see video)
(Handbrake shoes noise 100 % sure)
The fact that you can spin the wheel with your finger means they aren't too tight. Of course I can not tell if they are too loose.
When you get them right 2-3 clicks on the star wheel will freeze the wheel.
JeanPete
Post by JeanPete »
Hello abscate,
Thank you for your answer. Sorry for my bad English, but :
abscate wrote:Of course I can tell if they are too loose.
May I read "can" or "can't", please?
For shoes adjustment, I applied Volvo method : tighten with star wheel, then back up 5 notches.
Sorry I used English contractions which spell check made mistakes.
I cannot tell if they are too loose, of course.
JeanPete
Post by JeanPete »
OK, thanks again!
