Agreed on the trap. Great move on the o-rings.
The thin metal pipe is vacuum line for the rack mounted fuel pressure regulator. Sound like your car doesn't have that type fuel/return system, it may have the FPR up on the rail. In that case keep the fuel rail (and mounted FPR) from the old engine. Look for an FPR with vacuum line, not just a pressure damper, inserted into the rail.
All of a sudden she started making this loud knocking/tapping
- Has thanked: 311 times
- Been thanked: 817 times
shadetree_v70
- Year and Model: 1998 V70 GLT
Thanks! I didn’t know there were different FPR vacuum setups. I was going to keep the old fuel rail anyway so I will plan to run a new length of vacuum line from the air intake tube to the FPR directly, and avoid all the connections that could possibly leak in the future. I think along the top of the firewall will work better than the original path.
If you use the FPR in the fuel rail, just run short line from the FPR directly to the vacuum tree. That's the stock setup for rail-mounted FPR. The other FPR locations are down near the steering rack, passenger side, or back by the fuel filter. Your 98 almost certainly has the FPR near the rack.
shadetree_v70
Turns out the metal line wasn’t as bad as it looked. Sanded the rust off and sprayed it with rust fix, attached it to the new motor.
The past few weeks haven’t allowed me to do all that much but last weekend I was able to do some stuff. Subframe bushings, motor mounts, sway bar bushings. Fully decreased and power washed the engine bay. New motor is in now, and most of the installation is now complete, at this point I’m sorting vacuum lines and making sure all the electrical is connected. I expect to be driving it today.
There’s a hose that runs under the battery tray, about 3/8”. What is it?
- Has thanked: 1611 times
- Been thanked: 4071 times
That’s probably evap purge running to the canister on the driver side fender space. Trace it back to a valve with an electrical connector on the radiator to confirm
The 3/8 hose sounds like the brake booster vacuum line, from the intake manifold to the booster located on the firewall. In that case when you trace it there will be nothing in between, just a plastic connector.
shadetree_v70
Yup brake booster.
It runs!
Only problem is the inlet trans cooler hose won’t seal at the trans end. It’s a Volvo part so this surprises me. I tried adding an o ring and the leak slowed but it still leaks. Any advice?
It runs!
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
It's the lower one near the bottom of the valve body cover? It needs a new o-ring from Volvo (green one) plus the area needs be cleaned really well. I also did clean around with some acetone before installing the o-ring, then before refilling with oil I sealed around with some Grey Permatex sealant.
- oragex
My PCV was totally empty but the diaphragm inside was broken at 100k miles, new one and no more positive pressure.shadetree_v70 wrote: 20 Mar 2018, 10:51 As a preventative measure I dropped the oil pan of the "new" motor and did the sump o rings, inspected the breather passage up to the head, clean as a whistle (good sign), didn't see the need to replace the entire pcv system at this point. I can't believe the trap would be full or clogged at this point.
shadetree_v70
The area is clean and free of debris, and I think the tab where the bolt goes is too close to the flange, preventing the flange to press up to the o ring. The good folks at FCP are overnighting a new one on their dime to replace it under warrantee, so at least I have that
- 1067 Views
Last post by Clockboy
- 16 Replies
- 3073 Views
Last post by misha
- 3865 Views
Last post by 800artfreed
- 1102 Views
Last post by mash
- 23 Replies
- 2622 Views
Last post by Nevada1906
