head scratcher
RickHaleParker
Been thanked: 958 times
Re: head scratcher
Post by RickHaleParker »
Personally I would
  • 1. Run the tank low on fuel.
    2. Trace dye the remainder
    3. Get the dye up to the fuel rail.
    4. Let it sit.
    5. Then make darn sure I have not missed any leaks.
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 12 times
Post by sleddriver »
Having read all of this, I'd suspect the fuel pump (even if new) or the installation of it. Perhaps a hose is pinched somewhere? Or a seal/o-ring is squished out internally blocking the flow of gas?
Perhaps there's a way to test the pump outside of the tank? Where you could see the flow, test the pressure, and use a long length of tubing to give it some resistance to push gas against.
M1 10W-30 HM
