Vida CEM swapping
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
vtl wrote: 27 Jun 2020, 21:23 The guy is from Poland, be merciful he speaks any English :)
My old CEM is not responding even to Renesas E8... :(
Most of the Amiga guys where from Europe. A lot from Germany.
Did you brick the chip?
Around here used CEMs are $22.00 or $37.00 depending on if the clerk thinks they are "Computer Controls" $37.00 or "Computer Control Modules" $22.00. Don't as what the difference between the two terms is. I'm clueless.
Active
Past
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Had to split up the E8 and do a basic sanity check of my wiring. Ground pin I used looked suspicious, so had to RTFM :-D It turns out all ground pins have to be connected, "my" ground pin was indeed ground, but only used for connectivity check, not for signal reference. Wired the rest, and voila: "Version Information: VER.1.16"
Now need to figure out why my ESP32 code does not work. But at least CEM is not fried/bricked. Yet.
ZX-Spectrum hacker here =)
vtl
Post by vtl »
Ok, it works... Tons of problem, starting with CYT1076 level shifter that switches at 100 KHz, but Renesas wants more. Somehow they agreed at 200 KHz, but I may need to redo the shifter. Renesas is 5v, ESP32 is 3.3.
Also finding the right SPI mode was a bit challenging, especially with the previous problems in hands. LSBFIRST and MODE3 is what Renesas wants.
04:33:14.310 -> 0x56 0x45 0x52 0x2e 0x31 0x2e 0x31 0x36 0xff 0xff : VER.1.16⸮⸮
4am, already?
RickHaleParker
vtl wrote: 27 Jun 2020, 23:42 ZX-Spectrum hacker here =)
ZX81 was the first computer I bought. Then C= 64. A long line of Amigas. After C= blew it a slow migration to Windows.
Active
Past
shodanx
Year and Model: xc70 2001
Post by shodanx »
@vtl, check out ebay item 264566995629, 2x8 channel level shifter and should do well over 1mhz switching
Does anyone have high resolution scans of each version of the CEM ?
I bought 2x 2006 XC70 with highly suspect CEM. So now that I have two to fix, it is worth my while to learn how to clone and buy a programmer.
I'm looking at that Xprog programmer, I already have a willem 3.? programmer that might work.
From what I understand, CEM cloning is going to involved dumping ROM from two eeprom and two microcontrollers ?
Is dumping the data from the microcontrollers really necessary ? Surely they put all the real config data in the eeprom and the microcontroller just have the code ?
And with that said, is there anywhere that people have been collecting dumps from these microcontrollers and eeproms ?
I'd like to do some changes while I'm at it, I want to add keys, remove the alarm (which is always dead in those old cars anyway), remove the FOUR-C from the configuration...
vtl
Post by vtl »
Good news and bad news. Good news is I'm able to talk to CEM reliably at 57600 or 115200 bauds. Bad news there's no ID code match jitter :( The code measures the jitter in base freq. clocks, at 240 MHz it can detect variation in time for lifting the BUSY line as low as 4-5 us. However, collecting entropy in thousands runs I see no jitter. About 5 clocks deviation on average. Sigh...
Either the chip does not have the same BUSY nuance or I need to buy a waveform generator and downclock the chip (it runs at 30 MHz).
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
vtl
Post by vtl »
So, you are finding the ID over CAN withing a few seconds? Means, the range is very narrow. Good to know, thanks!
yagger
Post by yagger »
No, when I show process there are periods with fast forward video.
Detection can take 5 - 15 minutes actually.
vtl
Post by vtl »
This is still fast, given the CAN-bus itself is not very fast.
