You need to call cnc werx in geogia usa, and have a css block done, this is guarenteed for 650
On ebay there are 8000rpm 800hp rods for 300 us
Factory pistons are fine
Ebay has gtx 3071r clones for 350 us
Front mount 50mm intercooler with a 75mm outlet
Na intake has a better designe
That damn turbo manifold has to go,
It has to have 3" ex. Or better all the way back
And some larger injectors too, however if you use gasoline it is easeir to get it tuned right, at this point aviation 110 is best, but 13 gal. Of 85 with a half cup of nitro meth rc fuel should do.
Then you just tune it and see if the bevel gear and rear diff holds up.
200 V70 Boost and v.e. 2-3 Shift issue?
Yarddogperformance
- Year and Model: 2000 v70 cc se
- Has thanked: 2 times
Yarddogperformance
Oh yeah, another thing, and this will bend rods,
At around 2500 rpm you have a set oil pressure,
So you have say 40 psi holding the rod bearings off the crank, cooling the rods, with can handle a set pressure on the rod bearing area
Under boost your efective compression pressures rise by 50% per 7 psi, so 120 becomes 210 or something similar
This upplies more than 50% pressure on the rod bearing
Now your already at 150% of the original forces
8:1 has 140000 psi of pressure under detnation,
13:1 has over 200000 psi of pressure
So in order to keep from grinding the rod into the crank and bending a rod you need more valume and pressure. Hence why every one says no boost at low rpm, however if it has it factory like a volvo does, its all simple mods, just basically shimming and drilling.
This is where my lack of knowladge statement comes from, ive read every engine building book since 1945, and that particular book, the one writen in 45, by the use gov. For returning soldures has more info on octain than you would ever imagine.
And becouse i am autistic, my talents have lead me into opertunities most wouldnt even imagine, i have restored and moddified a 1929 auburn boat tail, ive driven carol shelbys personal ac cobra, and so on, just the sad quiet kid in the corner.
Ive seen done, imagined and failed at things no one has ever tried, and i know my facts even if slightly off the pricipals are all the same
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Okay... 140,000 psi? 200,000 psi?
Look. Maybe I’m autistic too, and that’s why I know that the first number is almost a gigapascal. The second is well on its way to 2 gigapascal. You have no clue what you’re saying - pressure in a high end, high tech racing engine might go as high as 1500 psi... but a gigapascal? I think not.
Have fun blowing up your Volvo. I’m out.
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- 4063 Views
Last post by sleddriver
- 25 Replies
- 11142 Views
Last post by veektor
- 675 Views
Last post by carguy124
- 1046 Views
Last post by JDS60R
- 1227 Views
Last post by cgw4jesus
