ODBII diagnosis
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
shaolinpat wrote: 17 Feb 2019, 15:31 What else can I do to narrow things down/make repairs?
You have a intake air leak. The engine revs when the starting fluid get sucked in through the leak.
Put a spray tube in the actuator and see if you can pinpoint the leak.
Spray starting fluid along the intake manifold. Intake manifold gaskets are a common source of leaks also.
Active
Past
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
shaolinpat wrote: 17 Feb 2019, 15:31 I sprayed carb cleaner around the engine. I put some down by the left side of the intake manifold (as I'm standing in front of the car), and that changed my rpms some. I really couldn't see where I was supposed to be spraying to get to the so-called "evil elbow", but was spraying where I thought it was. ...
This almost surely indicates a vacuum leak at the elbow. Get flashlight, look at the elbow. Is the elbow or the vacuum line crumbling or cracked? Spray starting fluid right at the elbow while you look at it, does the idle go up?
The vacuum lines are 20 years old, I'd just replace them all if you intend to use this car very much. I am not at all a fan of restoring everything in the engine bay just because someone once wrote it up in a DIY, but I do replace all vacuum lines any time I get a new P80 car just to wipe the slate clean.
shaolinpat wrote: 17 Feb 2019, 15:31 ... I also sprayed under the top side of the fuel rail, and got quite a lot of engine reving just to the right of the fuel cap. ...
This almost surely indicates a vacuum leak at the intake manifold. Was the PCV recently surfaced? It is super common for the little metal bracket on the corner IM bolt to get wedged under the manifold when finishing up a PCV job, and cause a vacuum leak. It is also somewhat common for the intake manifold gasket to fail in this area. Like above, get a flashlight and look carefully to pinpoint the area where starting fluid makes the idle surge, is it where the intake manifold meets the head? It's going to be either the manifold or one of the PCV lines underneath it, or possible the vacuum tree. If the IM gasket needs to be replaced this might be a good time to do the PCV also.
Post by erikv11 »
duplicate post deleted
