Where did you measure 8 and 13-15 PSI? Fuel pressure?
V70 won’t start. Out of ideas.
- Has thanked: 987 times
- Been thanked: 1078 times
I do not think your new plugs are the problem with proper gap. Volvo plugs are better for long term performance with the turbo, but others will work ok.
You may need to do a PCV service sometime. Search for this in this forum. The fact that you still have vacuum is good. Your readings are not bad.
Looking beyond your current problems, what is the general condition and mileage of this car and what maintenance has it had?
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Have you changed the fuel filter and how full is the tank? Is there a possibility of water getting into the tank?
I don’t think water got in the tank, but I did add heet anyways. Also, I’ve got 55 psi at the fuel rail. Would that rule out the fuel filter? I figured it would since I had pressure, but I’m a Volvo newbie so not real sure.
Thanks!
Thanks!
Hey folks, yet another update. I bought plugs from the Volvo dealership and brought one in to show the tech. He said that the particular ones I had were garbage (auto lite) but idk. I have it started at running reasonably well right now. Well, except the oil leak at the rear of the manifold….yikes!
Thanks to all for your continued help,
On these engines, the PCV is a system of pipes including water heating from the coolant. It becomes clogged with sludge over time. The test is to place a rubber glove over the oil fill opening. If the glove inflates at idle, the system is clogged. The result can be seal blow out.Vaswamp wrote: 25 Jul 2021, 18:50 Always had good maintenance from the dealer 127k, I’ve only had it a few months, have all the service records.
Do you think the pcv could’ve failed due to all the other issues?
Thanks
- 35 Replies
- 2463 Views
Last post by MotorTheresa
- 1990 Views
Last post by Sanatarium
- 12 Replies
- 2399 Views
Last post by E Showell
- 5757 Views
Last post by Oly850
- 1041 Views
Last post by vtl
