- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
A little Guibo judo
Current Volvos:
yanga001
- Has thanked: 59 times
- Been thanked: 110 times
Installed some remanufactured calipers on the project 99 2.3T S70 Auto. Had a fun time when i pushed the brake pedal without closing the bleed valves on the two front calipers. Needless to say i will need to bleed the whole system before testing it again.
DOH
DOH
2008 S60 2.5T Auto (Sold)
- Has thanked: 1502 times
- Been thanked: 3817 times
It doesn’t qualify or a blooper until the Piston pops out....
duke1
- Year and Model: 855 1994 10v
- Has thanked: 416 times
- Been thanked: 34 times
the missus found her carpet in the volvo rather soggy!turns out when i fitted the new heater matrix i was a bit wimpy tightening the t25 fastener and had seepage.
so i have tightened it up and dried it off left some tissue under it for tonight which i hope to find still dry in the morning,all cos i was scared id overtighten it and strip the thread,,,,,.
also got a black light today and going hunting for ac leaks,wish me luck im going in!!!!!!peace
brunocerous
- Year and Model: 1998 V70
- Has thanked: 284 times
- Been thanked: 36 times
Finally got the starter out of the T5 after a no-crank, no-start situation, bench tested it, and it was fine. Put everything back together, and it started right up.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
- ZionXIX
- Has thanked: 64 times
- Been thanked: 194 times
Of course it didbrunocerous wrote: ↑19 Sep 2020, 20:10 Finally got the starter out of the T5 after a no-crank, no-start situation, bench tested it, and it was fine. Put everything back together, and it started right up.
- Has thanked: 304 times
- Been thanked: 517 times
Ahh... one of those fun intermittent issues. It seems everything that goes wrong on my cars is like that!
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
I did that once with my 850 starter. It was a connection issue ( but not the kind that makes sparks luckily!)
Today I finished polishing all the big panels, some little spots to finish. Looks so much better red than pink.
Oil change (Castrol GTX 10-30 for the winter), flushed out 3 qts of ATF (pretty dark), new wipers, couple of little things.
As I was poking around under there, I saw that quite a bit of oil is coming down the front / intake side of the block and blowing back across the pan. Not the pan gasket, it looks to be pretty high. Better light and a mirror tomorrow.
What’s up there under the intake that has oil pressure? Does the pcv box have any pressure?.. It’s just a vapor separator. Head gasket? (OH NO MR BILL...) hmm.
It may be one of the rear cam seals letting the oil trickle down. Those leaks tend to travel.BlackBart wrote: ↑19 Sep 2020, 22:13 I did that once with my 850 starter. It was a connection issue ( but not the kind that makes sparks luckily!)
