BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
j-dawg wrote: 21 Sep 2020, 01:17 Does your dipstick stay seated while you go ham on the throttle?
Yes. But glove test shows a slight bit of pressure, so I feel like I should do the PCV while finding the leak.
It sat for 6 months and didn’t leak a drop, then I warm it up, let it idle a long time, and take it on the freeway full blast. Something changed due to that - dry seal, too much crankcase pressure, cracked hose.....
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
So a few weeks ago I finished overhauling my AC system with a new compressor, dryer and a million seals. When I originally went to get it charged the machine would stall at about 0.25 lbs. Today J went back and they used an older machine that had zero problems charging the low port only. Turns out the newer fancier machine really dislikes not having a high side port. My AC has never been so cold. Its fantastic.
Has thanked: 1836 times
Been thanked: 1709 times
Great news on the A/C. Funny how old equipment is becoming more important to owning these old cars.
Took the 'R' to the dealer today to drop it off. Has only done a couple of very short runs since moving to new home in early January. When I uncovered it in the spring it had no coolant in the header tank and evidence it had blown it out through the cap. Worried about the drive to the dealer with a lot of traffic and traffic lights. Car ran fine and no over-heating issues. They will check it over and if nothing serious they will also flush the trans for me. Sucks not having access to a garage to work on the car. Maybe in a couple of months if all goes well!
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Well, The PCV has "flow" if there is a lack of adequate vacuum, oil will go where it can, if the air rushing past from the cooling fan made enough pressure differential, it could theoretically siphon vapor from a split hose or loose fitting. more likely a bad hose just spewing. Possibly the oil cooler or lines for it, or even the oil thermostat, depending on where the airflow through the engine compartment takes things. I would start at the cooler fittings at the radiator, because airflow, and work backwards from there. I would expect air to eddy up under the intake manifold, so that is where it ends up?
And as far as the oil pressure switch, the normal mode of failure on those is not at the threads, but between the body and the core.
Current Volvos:
Has thanked: 1498 times
Been thanked: 3810 times
You’ll never get out of the Hood with North Sails
( sailing humor, tends to be tacky)
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
FLXC90 wrote: 21 Sep 2020, 15:45 Well, The PCV has "flow" if there is a lack of adequate vacuum, oil will go where it can, if the air rushing past from the cooling fan made enough pressure differential, it could theoretically siphon vapor from a split hose or loose fitting. more likely a bad hose just spewing. Possibly the oil cooler or lines for it, or even the oil thermostat, depending on where the airflow through the engine compartment takes things. I would start at the cooler fittings at the radiator, because airflow, and work backwards from there. I would expect air to eddy up under the intake manifold, so that is where it ends up?
Yup, the washer usually leaks. Mine is leaking, and the switch on my old V70 was leaking even worse than my current one.
It’s Earl delivery day finally.
Ludwig Van cleared for departure runway I787 left.
Acquire Troy, Bennington, Brattleboro, ST Johnsbury flight level 30, speed 60 mph
I’ll put the photos into Road Trip
Year and Model: 2001 V70
Been thanked: 1000 times
Post by volvolugnut »
I would like to be taking road trips, but your photo trips are an acceptable substitute. Thanks.
BlackBart
Post by BlackBart »
abscate wrote: 21 Sep 2020, 18:52 You’ll never get out of the Hood with North Sails
R R R !
(I have a retired friend here who used to work for Ted Hood in Marblehead back in the day)
loveMy850
Year and Model: 1994 850 WAGON
Has thanked: 97 times
Been thanked: 4 times
Post by loveMy850 »
I replaced my O2 sensor.
