2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 999 times
Post by volvolugnut »
dikidera wrote: 09 Sep 2025, 01:43 On my previous Aw55 transmission, changing the oil at one point yielded no benefits. And when I say changing the oil, I do mean 40 actual quarts over a span of a year. At some point I replaced it.
My "new" transmission is somewhat better and I think it's the first where I've seen a benefit to changing the oil, but we will see, I've usually observed that any benefits are usually temporary. And the broken torque mounts have definitely exacerbated any bad shifting.
I did a 3.4 quart change with genuine Volvo Jws3309 oil. There was some slippage when going very very light throttle, barely touching it, but after going 300km, it does seem to have improved.
I agree with your thoughts. Oil changes have diminishing benefits over time as the transmission degrades. However, I think the fresh ATF does help clean the valving after a couple hundred miles. Oil drain and fill is cheap and easy compared to transmission replacement.
Starbuck
Year and Model: 2004 XC70
Has thanked: 46 times
Been thanked: 9 times
Post by Starbuck »
Ben finally got some TLC this week.
His hoses are mostly original and the turbo hoses were getting really gummy. I want to change all coolant hoses to yellow silicone hoses but I can't find them online. I think I'll buy straight hoses and shape them with springs so if anyone knows the dimensions offhand...let me know. They still look good but seeing "03" stamped on my radiator hoses is starting to stress me out.
2004 XC70 - "Benjamin Wash"
2008 XC90 3.2 - "Norman" (RIP totalled)
2004 S60R - "Nial" (Sold to a good home)
1991 Mazda Miata - "Origami"
1982 VW Rabbit Pickup - "Judy"
Starbuck
Post by Starbuck »
I've been meaning to install yellow light film I got in a trade on any car for about a decade now and I finally did it!
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 603 times
Post by vtl »
The car became boaty on the road, which I ignored sufficiently enough, since it runs on soft fat 29" AT tires. Decided to check the pressure and here you go: 25 PSI. Lost about 5 PSI in 2 years. Aired up to 35, problem solved.
That's the kind of Volvo problems I like dealing with! :)
dikidera
Year and Model: S60 2005
Has thanked: 67 times
Been thanked: 175 times
Post by dikidera »
I must ask, did all turbo petrol models come with vacuum front and rear engine mounts?
vtl
Post by vtl »
dikidera wrote: 14 Sep 2025, 06:55 I must ask, did all turbo petrol models come with vacuum front and rear engine mounts?
Only diesel.
Starbuck wrote: 12 Sep 2025, 20:00 Ben finally got some TLC this week.
Silicone hose is great for long life, BUT silicone is slippery. Be sure your hose clamps are tight. If they can't be kept in place with high boost, use double clamps. We learned this with industrial turbo diesel engines.
dikidera
Post by dikidera »
vtl wrote: 14 Sep 2025, 07:57
Only diesel.
Too bad, I was attempting to make a connection between NA and turbo mounts, hoping that turbo were vacuum controlled and why they may last longer than NA.
vtl
Post by vtl »
dikidera wrote: 18 Sep 2025, 00:18 Too bad, I was attempting to make a connection between NA and turbo mounts, hoping that turbo were vacuum controlled and why they may last longer than NA.
Buy turbo ones if you believe they last longer. But I think it is factory vs replacement. Production was moved to Turkey, I think. I had Hutchinson (who makes them for Volvo) cracked and collapsed after a very short time. Was able to source Volvo branded made in Europe, they are still in tact.
dikidera
Post by dikidera »
I plan to replace the upper and lower torque mounts. I have excessive engine movement when shifting. But I do believe the front and rear engine mounts also contribute to this. The best option would always be replace it all at once, but it is also the most expensive option, and if we are talking Volvo blue box, very expensive for all of them.
