OpenMoose
Vida CEM swapping
Treur
- Year and Model: 2007 V70
- Has thanked: 3 times
- Been thanked: 7 times
I can get a PIN code in 12 seconds. However, it's useless for read/write (it can be read, of course, but very slowly). It's much easier to work without a PIN code using OBD. For example, TechNest.
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
You can extract the CEM-B pin code in 12 seconds?Treur wrote: 26 Dec 2025, 06:34 I can get a PIN code in 12 seconds. However, it's useless for read/write (it can be read, of course, but very slowly). It's much easier to work without a PIN code using OBD. For example, TechNest.
Treur
Yesvtl wrote: 26 Dec 2025, 07:06You can extract the CEM-B pin code in 12 seconds?Treur wrote: 26 Dec 2025, 06:34 I can get a PIN code in 12 seconds. However, it's useless for read/write (it can be read, of course, but very slowly). It's much easier to work without a PIN code using OBD. For example, TechNest.
P.S. I Lied... 13 seconds.
This would make some sense if CEM allowed loading and executing SBL with a PIN code other than 0000000000
Dudde
- Year and Model: 2005 V70 and more
- Has thanked: 16 times
- Been thanked: 17 times
So your saying technest can read/write the CEM without pincode? Even the keys and sync data?Treur wrote: 26 Dec 2025, 06:34I can get a PIN code in 12 seconds. However, it's useless for read/write (it can be read, of course, but very slowly). It's much easier to work without a PIN code using OBD. For example, TechNest.
Dudde
Works on 90% on CEM B modulesvtl wrote: 26 Dec 2025, 07:06You can extract the CEM-B pin code in 12 seconds?Treur wrote: 26 Dec 2025, 06:34 I can get a PIN code in 12 seconds. However, it's useless for read/write (it can be read, of course, but very slowly). It's much easier to work without a PIN code using OBD. For example, TechNest.
Treur
AbsolutelyDudde wrote: 26 Dec 2025, 07:38So your saying technest can read/write the CEM without pincode? Even the keys and sync data?Treur wrote: 26 Dec 2025, 06:34I can get a PIN code in 12 seconds. However, it's useless for read/write (it can be read, of course, but very slowly). It's much easier to work without a PIN code using OBD. For example, TechNest.vtl wrote: 25 Dec 2025, 11:30
"30-second no-solder recovery of CEM-B pin is being tested " interesting...
MC68376 + 28F400B5 — 29bit, Flash RW. [No PIN required]
Dudde
How long does reading and writing take?Treur wrote: 26 Dec 2025, 07:40AbsolutelyDudde wrote: 26 Dec 2025, 07:38So your saying technest can read/write the CEM without pincode? Even the keys and sync data?Treur wrote: 26 Dec 2025, 06:34
- 8970 Views
Last post by RickHaleParker
- 8788 Views
- 27 Replies
- 27599 Views
Last post by cn90
- 10192 Views
Last post by jonesg
- 5411 Views
