Also, with the jack I raised the tie rod end where it connects to the knuckle, and after a minute or so of heat, more PB blaster, and some pounding with a sledge hammer, the tie rod end finally came free!!! Thank you, abscate, for your recommendations on getting these unbolted!!
I was not having any luck with getting good access to the rear/lower motor mount, so I removed the bolts to the sway bar on the driver's side. That was a good exercise in being patient - not much room there to wiggle a ratchet and socket. But finally got those two bolts out with a deep well 14mm socket and from underneath the car, an open end 14mm wrench. This gave me a bit more room to access the bolt to the mount.
I went back underneath the car to try to break free the 14mm bolt to the bottom of the rear mount. The socket did spin to no avail; the top of the bolt is now rounded
I did manage to tap (hammer is more like it) a 13mm open end wrench onto the beaver tail bolt head and with a cheater bar was able to break the bolt free. But now the wrench is stuck on the bolt head
Tonight, I'll cut the power steering lines using some bolt/wire cutters so they will drain overnight. Then in the morning I can cut back the lines to give me a bit more room to tackle the mount. I am determined!! Stay tuned!!:))
