Part 2: PNP Removal
- osman
- Year and Model: 2002 c70 hardtop
Re: Part 2: PNP Removal
In addition to doing the job without disconnecting the wiring harness, I use an 22mm O2 sensor socket instead of channel locks to remove the nut on top of the pnp sensor. I can do the whole thing in under two hours now. I love this site.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Have you tried starting in neutral? After eyeing it up when I did it my reverse lights worked fine but I couldn't start in neutral anymore. The switch was misaligned just enough so everything else worked but the engine wouldn't start in neutral.turbozutek wrote:I've never understood the song and dance about alignment either. You put the switch on the shaft with all the lines aiming towards the stamping on the switch housing. If it's out of alignment the lines don't match up by eye - it's really, really easy.
That's it. I've done this almost 10 times with various 850's and s70's and I've never once thought about using a tool to help. If anyone reading this is put off doing this job by the scary looking 'alignment phase', don't be: it's piss simple!
- Been thanked: 472 times
Quick question,
I understand this is a relatively easy fix.
Has anyone here had an irreparable issue and has to buy a new PNP switch, which is about $130 at Volvo dealer:
http://www.trademotion.com/parts/index. ... eid=216970
I will add some photos hoping to help someone.
1. Note during removal, the bolts for the shift cable are centered in the oval slots.
If you pay attention to this, there will be no need to adjust the shifter cable later.
(But you need to check the shifter later anyway to be sure P is P, R is R, D is D etc.).
2. Note that I left the PNP attached to its connector.
One less step to worry about.
Note the gasket, do NOT lose it!
3. Note that the copper U-clip is mounted on a vise-grip to be filed straight and square.
- Has thanked: 292 times
- Been thanked: 765 times
The concept is great here but the nuts will not all be in the same place on different cars. That is, they will not always be in the center. So the key is to put them back where they started, not to put them in the center. As suggested elsewhere in this thread, before you start use a Sharpie and draw an outline around the nuts.cn90 wrote:I will add some photos hoping to help someone.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Hey polskamafia mjl,polskamafia mjl wrote:turbozutek wrote:...Have you tried starting in neutral? After eyeing it up when I did it my reverse lights worked fine but I couldn't start in neutral anymore. The switch was misaligned just enough so everything else worked but the engine wouldn't start in neutral.
This is too funny. I have the exact same issue but I will not lose sleep over it: opened the PNP switch to fix "no reverse light". Put everything back. Everything else works just fine: P, R, N, D etc.
Start perfect in P but not in N.
Personally I do not care because I have never needed to start the car in N in 15 years driving Volvo.
But I'd be curious to know where the issue is.
Hey cn90 (or anyone), comments welcome:cn90 wrote:...polskamafia mjl wrote:...Have you tried starting in neutral? After eyeing it up when I did it my reverse lights worked fine but I couldn't start in neutral anymore. The switch was misaligned just enough so everything else worked but the engine wouldn't start in neutral.
I have the exact same issue ... opened the PNP switch ... Everything else works just fine: P, R, N, D etc. Start perfect in P but not in N.
As polkskamafia stated a misaligned switch is of course that is the most likely issue, but cn90 just dismisses it so I am curious, what else are you thinking is going on here? Maybe you sanded the contacts too short or didn't properly clean a track or something? Can't see it being anything other than the switch is misaligned.
I will need to do another PNP rehab once it gets warm enough to go in there, want to make sure I have everything covered.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
polskamafia mjl
I like having my car work the way its supposed to. I agree most times there is no reason to worry about whether it will start in neutral or not, I just prefer having things work the way they were meant to. I still believe some precision should be used when aligning the switch. Everyone is free to use their own judgement however.
precopster
- Year and Model: Lots
- Been thanked: 128 times
The other day I had two PNPs in front of me, a 850 '96 GLT that had been pulled from a low mileage transmission at around 70K miles and a PNP from a 960. I was supposed to have cleaned the 960 PNP but instead the brain went foggy and I opened up and cleaned out the 850 one. It had near perfect straight copper contacts and the grease looked OK so I cleaned it up, retensioned the springs and put some new grease inside.
By contrast the wife's '95 850 PNP was toast earlier this year at 82K miles with steeply worn coppers that had to be filed back quite a lot. It worked brilliantly after the clean with reverse lights being restored and no more flashing arrow and stuck in first syndrome. It got me thinking that Volvo must have either overtightened the wife's one, or used a different supplier or perhaps these things just wear out markedly once the grease inside goes stale and crusty.
I finally have a little time to play with this "no crank in N" issue.polskamafia mjl wrote:I like having my car work the way its supposed to. I agree most times there is no reason to worry about whether it will start in neutral or not, I just prefer having things work the way they were meant to. I still believe some precision should be used when aligning the switch. Everyone is free to use their own judgement however.
- Remove Air Filter Housing: 2 min.
- Remove battery and battery tray: 2 min.
I played with the adjustment 13-mm bolts to adjust the cable to all kinds of extreme: all the way to the front and back and anything in between, roughly 10 different settings: guess what, car does not crank in Neutral.
Then I discovered that (same observation as someone else earlier) that if I leave the shifter in "N" but push it just a tiny bit forward (still in the "N" slot but at the forward limit of it), then the engine crank! Try and you will see.
I do not have the starting circuit in front of me, but I wonder if the neutral start circuit is somewhere below the shifter itself (rather than on the PNP switch).
As I mentioned before, I never used this feature (crank in neutral) in my 14 years of ownership.
However there may be a rare exception: if you are on highway and engine stalls, and you want to re-start engine ASAP, so you would shift to neutral to start. So I can see this feature useful in very rare situation.
