Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Hyppis wrote: 08 Apr 2026, 10:37 Really interesting how there is absolutely zero information about that anywhere that I found (before now lol) so a big thank you!
That's not entirely true. If you read all 438 pages of this thread carefully, you may even find the answer to the ultimate question of life, the universe, and everything.
Hyppis wrote: 08 Apr 2026, 10:37 It at least seems like I got the CEM PIN anyways, so is there any better way to check that it is the correct one?
Send a CAN message with unlock request if you are bored. Buy a feature in VDASH if you are rich. Drink a beer otherwise, your pin worked.
Hyppis
Year and Model: V70 -02
Post by Hyppis »
That's probably true actually, congrats on page 439 btw :)
Now before I did anything else I put in my PIN and backed up all my modules through VDash, but I can't figure out where the backups actually go, so it seems that they're stored in the cloud on their servers.
And also thanks for the help, probably gets boring to answer these types of questions the 100th time and beyond lol
Dudde
Year and Model: 2005 V70 and more
Has thanked: 16 times
Been thanked: 17 times
Post by Dudde »
Hyppis wrote: 08 Apr 2026, 11:18 That's probably true actually, congrats on page 439 btw :)
If OpenMoose finds pin on CEM B it is correct, the check pin does not work on that CEM model
Hyppis
Post by Hyppis »
Dudde wrote: 08 Apr 2026, 11:25
[the check pin does not work on that CEM model
Well there we go, glad to know I wasn't the only one doing something wrong lol
Also how did you know that if I can ask?
Dudde
Post by Dudde »
Hyppis wrote: 08 Apr 2026, 11:42 Well there we go, glad to know I wasn't the only one doing something wrong lol
Look in the about page on the OM app and you'll see my name 😁
I have bench setup for P2 cars so i have tested almost every function
dwappertam
Year and Model: 2001 S60 P2
Has thanked: 3 times
Post by dwappertam »
````Hi all,,
First of all verry nice to see the development still on the CEM-B .
The fact there are programs now that can do the pin ,,,, awsome..
My question. I got a new blank id48 transponder key for my ignition on my s60 01 p2 . i know that i can use the VolvoSynchro V1.4 to get my cem aligned with my ECM , but i want to get my key working and did not figure out what i have to do to get that new transponder to work in my car . can anybody help me on my way , Thanks in advance. i Got the CEM pin dont know how to get the immo pin
Greets
Dwappertam
V70user
Year and Model: 2003 V70 2.3T5
Has thanked: 1 time
Been thanked: 3 times
Post by V70user »
dwappertam wrote: 15 Apr 2026, 16:18 i know that i can use the VolvoSynchro V1.4 to get my cem aligned with my ECM
VolvoSynchro ver1.4 doesn't work. It can set 10 synchronization bytes, but doesn't give You the eleventh byte,
which together with 10 synchronization bytes allows to start the engine.
Without correct 11th byte value - engine will not start. It will crank but no run
That is what I mean :
vfred748
Year and Model: S60 2006
Post by vfred748 »
Hello mates,
I've succesfully decrypted another CEM L on bench. Make a clone with ioterminal.
When i plug the new CEM the odometer does not work. The car starts but non odometer.
Any ideas ?
machadosk
Year and Model: XC90 2004 T6
Post by machadosk »
So will this work on a Volvo xc90 t6 2004
Ironmarkbiltekniker
Year and Model: 06 V50
Post by Ironmarkbiltekniker »
Built the teensy decoder. Connected it to the vehicle. Run software. When looking at the log it sends the LS can command. Cant find cem part # on ls can but it finds it on hs can. Shows it finding the part number. Puts vehicle into programming mode. Whole vehicle shuts down as expected. Starts the counter. Ends up going to 99 0 latency. Reboots vehicle then says cant find cem part number. Tried three different kinds of canbus modules like waveshare etc. checked wiring and diagram multiple times. Added in 12v converter to power externally didnt change anything. Adding and removing grounds didn't change anything.
