Vida CEM swapping
porcupine7655
Year and Model: 2006
Been thanked: 20 times
Post by porcupine7655 »
Next step for me is to understand the remote fobs.
Dumped the UEM using BDM, there was an stadard HC12 chio with a ready unpopulated footprint just beside the cpu itself.
No locks, just readout with no problems.
Used Claude a lot to reverse how it works and how the remote is received and decoded. It is "standard" KeeLoq encryption. No extra layers.
To be able to decrypt the radio frame there is needed two pieces, the serial and the key. The serial is in clear text in both eeprom and on the air. The key is also in plain text in eeprom, but not in air.
After some struggle we, Claude and I, managed to build an air sniffer using an sdr (software radio). In my case a Adalm-pluto. Only reason using this is that I had it since before when I worked on GPS and needed something that could simulate GPS in an controlled environment.
So with this and the key from eeprom we had an sniffer that I can decrypt messages from my remote. This was just for me to verify that I had all pieces correct.
Next step from this was to build an new application into a Flipper so it can act as my missing fob. This was also successful.
After all this I was not near my goal to have one more working fob.
I took one side step and bought one cheap china fob. It was no use. Looks like all of this fobs have same serial and same key. So if I manage to learn this key into my car, everyone with same key can open my car. Not good. One other problem was that with the fob you get two numbers. One short and one long key. The short is the serial in KeeLoq. The long is done some unknown transformation into the KeeLoq key. I wasn't able to find how this transform is done. So this is a dead end for DIY. I also looked into how this cheap key mas made. They have a 1MByte big flash and a small cpu. The cpu is locked. During bootup on each button press it reads the first part of the flash. Then it reads a small block of data. Next press is take a jump and reads some data little higher in memory. So this memory is a prerecorded set of frames. Every keypress jumps one block forward. Each block contains all buttons. When it reaches end it sends only zero. No way to restart. It have limited number of presses it can use.
So I looked more into the original fob, it have a HCS412 chip. It is not possible to read out the key from this chip, but it is possible to write! And from my experiment I know exact how the radio frame shall look and how the key is saved in the eeprom. So I (read Claude) write an arduino sketch that programs the chip. I have just tested and can program it. My sniffer can read it correctly.
I haven't tested on the car yet, I don't have it at home just now so it can take a couple of weeks before I can test.
As usual here is some information
blue is magic number for key information so firmware know where to read
There is space for 6 keys, yellow and green is the first two.
The 4 bytes is serial, 8bytes KeeLoq key
Code: Select all
./run.sh rx --seconds 4 --save capture.npy --key xxxxxxxxxxxxxxxx
# /home/de/projects/Volvo BiFuel/keys/share/sniffer/.venv/bin/python /home/de/projects/Volvo BiFuel/keys/share/sniffer/pluto_recorder.py --uri ip:192.168.2.1 --freq 433920000 --fs 3000000 --save capture.npy rx --seconds 4.0
# capturing ~4s (45 buffers) at 433.9200 MHz - PRESS THE FOB NOW ...
# strongest burst: spread 2837, SNR ~65.7 vs noise floor
# carrier peak = LO +5.6 kHz  -> true carrier ~ 433.9256 MHz
# pulse widths (us): 39 pulses, min 504  median 902  -> Te ~ 902 us  (config default 780)
#      504 us | # (1)
#      721 us | ### (3)
#      829 us | ############################# (29)
#     1263 us | # (1)
#     1696 us | ##### (5)
# saved raw I/Q (11796480 samples) -> capture.npy
# capture.npy: 11796480 samples @ 3 MSPS
# 1 distinct frame(s) from 1 decoded window(s)
# frame seen in window(s) 1784-2284 ms   Te~870us
  polarity        : 1        repeats seen : 1
  checksum        : PASS
  raw bytes (0..8): C6 34 7F E6 56 34 12 00 24
  on-air bits     : 011000110010110011111110011001111110110100111000101000100000000000100100
  HOP             : 0xE67F34C6  (KeeLoq — bytes 0-3 LSB-first)   [raw MSB-first 0xC6347FE6]
  SERIAL          : 0x00123456  (LE)   24-bit 0x123456   MSB 0x00
  CHECK byte      : 0x24  -> data(b0)=0  chk0(b1)=0  chk1(b2)=1  stop(b5)=1   [valid]
  KeeLoq decrypt  : plaintext 0x80B70018
    button        : 0x8 (UNLOCK)
    overflow      : 00
    disc (25:16)  : 0x056   (== serial&0x3FF)
    counter (15:0): 0x0018  (24)
Log from my sniffer when it decodes correctly. disc field shall match part of serial
If not correct it looks like
Code: Select all
  KeeLoq decrypt  : plaintext 0xE1C5707F
    button        : 0xE (?)
    overflow      : 00
    disc (25:16)  : 0x1C5   (!= serial&0x3FF (0x0B7))
    counter (15:0): 0x707F  (28799)
Flashing the key with new configuration, serial and key.
I also attach source for the sniffer and flasher
The key and serial from eeprom goes right into the arduino sketch
Just remember, use at own risk. I have used it and was able to do something but it don't mean it works for you.
hcs412-flasher.zip
(4.15 MiB) Downloaded 8 times
sniff.zip
(36.97 MiB) Downloaded 6 times
Dudde
Year and Model: 2005 V70 and more
Has thanked: 17 times
Been thanked: 17 times
Post by Dudde »
porcupine7655 wrote: 08 Sep 2026, 14:43 Next step for me is to understand the remote fobs.
Code: Select all
#      504 us | # (1)
#      721 us | ### (3)
#     1263 us | # (1)
  checksum        : PASS
    overflow      : 00
Code: Select all
    button        : 0xE (?)
    overflow      : 00
I would be careful on what is good to be posted out in the open, just saying.
I can share how to steal a P2/P3 car also in less than a minute if it's ok for everything to be out in the open 😂
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Dudde wrote: 08 Sep 2026, 15:00 I would be careful on what is good to be posted out in the open, just saying.
Megamos was broken long ago, with the academic paper written: https://flaviodgarcia.com/publications/ ... Crypto.pdf. Beef up your Anthropic account, pass the pdf to Fable, crack beer open and wait a bit.
Dudde
Post by Dudde »
vtl wrote: 08 Sep 2026, 15:05
Just need blank chip, few lines of code sent on canbus and voila away we go. Mechanical part depends ofcourse on the actor but if it you know what you do its simple
porcupine7655
No, it is not so easy. Yes you can crack KeeLoq from air frames. But it is not so easy that you need one frame and then you can calculate the key from it. The latest I read was that you have 65000 frames and can do the calculations within a week.
What I show here is that if you have a dump of the uem eeprom you can make a key that matches that information.
But if some evil person can take a eeprom dump of the uem, they can also write to the eeprom in the uem. If they can write they can modify it to match a key they already have. It is much easier.
What I have shown is that you can learn a key to a car and not what already is out, learn a car to a key.
So from security point of view there is nothing new here. It doesn't weaken it. It is in same level.
Do you have other information? An new novel attack on KeeLoq that is not published?
Dudde
Post by Dudde »
porcupine7655 wrote: 08 Sep 2026, 22:26
The keeloq algorithm is weak on this system, it's much easier than you think. Or i just got lucky with my test's, but i didn't continue the work because i have no need for it as i can generate new codes to a used fob.
And i didn't mean anything in a bad way, it's good to see more people are interested in this kind of stuff.
My opinion is just that not everything is good for the public, ofcourse sooner or later everything will be cracked.
vtl
Post by vtl »
Dudde wrote: 08 Sep 2026, 22:42 The keeloq algorithm is weak on this system, it's much easier than you think. Or i just got lucky with my test's, but i didn't continue the work because i have no need for it as i can generate new codes to a used fob.
You, guys, live in a bad neighborhood ;) My cars are all unlocked. Volvo even has the only key glued to the immobilizer antenna, can start it with a screwdriver.
Dudde
Post by Dudde »
vtl wrote: 09 Sep 2026, 04:50
Yeah not possible nowadays anymore.. everything has to be locked. But locks are just for honest people
RickHaleParker
Been thanked: 981 times
Post by RickHaleParker »
Dudde wrote: 09 Sep 2026, 04:57 Yeah not possible nowadays anymore.. everything has to be locked. But locks are just for honest people
A thief once told me "Locks keep your friends out" .
Active
Past
Treur
Year and Model: 2007 V70
Has thanked: 3 times
Been thanked: 7 times
Post by Treur »
Are you serious? Is it really that hard? I wrote a generator for the 412 in a single evening. It programs via PicKit, Arduino and via my own programmer, which I cobbled together from an ST-Link dongle.
