Vida CEM swapping
Arty
Year and Model: 2006 S60
Has thanked: 7 times
Been thanked: 5 times
Post by Arty »
That’s all I can say on the matter, lads)))
Yariy
Year and Model: XC90
Has thanked: 16 times
Been thanked: 10 times
Post by Yariy »
Test the `ShimTSDiCE32` shim — a native 32‑bit DLL (C++, MSVC, Win32/x86) that exports the standard 14 J2534 v4.04 functions (`PassThruOpen` … `PassThruIoctl`) and passes them through to the actual Volvo DiCE driver — `TSDiCE32.dll`. The purpose of the shim is to selectively translate protocol identifiers that the DiCE driver does not understand: the J2534-2 protocol `CAN_PS` (`0x8004`) is replaced with the proprietary `LS-CAN` DiCE (`0x10000001`).
Call chain:
Application (J2534)
│ PassThru* (__stdcall)
ShimTSDiCE32.dll (interception + translation of ProtocolID/Flags)
TSDiCE32.dll (real Volvo DiCE driver)
Volvo DiCE equipment
Run the file register-shim.bat to copy the DLL and add the device “Volvo DiCE (ShimTSDiCE32)” to the registry.
In your program, choose the "Volvo DiCE (ShimTSDiCE32)" device.
ShimTSDiCE32.zip
(48.59 KiB) Downloaded 6 times
Arty
Post by Arty »
Yariy wrote: 15 Sep 2026, 04:26 Test the `ShimTSDiCE32` shim — a native 32‑bit DLL (C++, MSVC, Win32/x86) that exports the standard 14 J2534 v4.04 functions (`PassThruOpen` … `PassThruIoctl`) and passes them through to the actual Volvo DiCE driver — `TSDiCE32.dll`. The purpose of the shim is to selectively translate protocol identifiers that the DiCE driver does not understand: the J2534-2 protocol `CAN_PS` (`0x8004`) is replaced with the proprietary `LS-CAN` DiCE (`0x10000001`).
Call chain:
Application (J2534)
Copy ShimTSDiCE32.dll next to the driver: C:\Program Files (x86)\DiCE\Tools\
Run the registry file register-shim.reg to add the device "Volvo DiCE (ShimTSDiCE32)".
I actually did something pretty much like that. Just a bridge. The main thing is that the software thinks it’s using DICE.
Yariy
Post by Yariy »
I have the opposite situation)) — so that the program thinks it’s working with a J2534 adapter, but in reality it’s working with DiCE.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Code: Select all
                     Software poll  Hardware capture
Valid samples                 1024              1024
Invalid samples                  0                 0
Minimum (us)                84.030             0.107
Maximum (us)                90.087             0.213
Range (max-min)              6.057             0.107
Mean (us)                   87.077             0.171
MAD (us)                     1.945             0.000
Active
Past
Yariy
Post by Yariy »
RickHaleParker wrote: 16 Sep 2026, 22:50
Code: Select all
Invalid samples                  0                 0
Could you please explain what this is?
RickHaleParker
Yariy wrote: 17 Sep 2026, 05:36
Code: Select all
Invalid samples                  0                 0
Working on using the Cortex-M7 PWM hardware timer peripherals and DMA as a co-processor.
The idea is to wean the jitters out of the latency measurements.
The above is a comparison between the current version of the "co-processor" vs the current the Software polling method in the Volvo CEM Cracker.
Active
Past
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
RickHaleParker wrote: 17 Sep 2026, 05:47 Working on using the Cortex-M7 PWM hardware timer peripherals and DMA as a co-processor.
87 us in your table is the average response latency from CEM. One loop in software on Teensy is under 100 ns.
RickHaleParker
vtl wrote: 17 Sep 2026, 05:59 87 us in your table is the average response latency from CEM. One loop in software on Teensy is under 100 ns.
I need to find a different arming trigger for RX. The CAN transceiver mirroring is tripping this one up.
Active
Past
vtl
Post by vtl »
RickHaleParker wrote: 17 Sep 2026, 07:44
I don't think more precision will help. The problem is the slowest domain clock - the CAN-bus. 500 KHz hides all the variability happening on the 30 MHz (CEM) side. P1 CEMs are running at 4 MHZ - only 8 MCU clocks per 1 CAN clock, and they are much easier to crack.
If ARM code execution gives a lot of jitter then what may help is turning off the speculations in ARM core, so it would execute the code slower, but with linear timing. Speculative execution and power saving.
