Earnt my p80 stripes today , got my first dash squeak.
Big Crunch going over a pot hole - squeaks and ‘loose mooring’ sounds ensued ...
- Has thanked: 2211 times
Eek! Or is that squeak, squeak?
- patcal
- Has thanked: 99 times
- Been thanked: 10 times
Installed Philips X-treme +130 bulbs in my 98 S70. Managed to break the drivers side turn signal tabs. Got new assemblies ordered. Figure do both sides.
Pat Callaghan Jr.
98 S70 GLT
98 S70 GLT
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Ugh..I have that. The hotter the dash gets with the heater on, the more it squeaks.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Broke mine awhile back going over a cattle guard at sloooow speed. I am waiting till I have multiple things to do in the dash before I take it out, so I am using one of these "wind bags" or "air shim" till then. In my case it has worked surprisingly well. Don't see or feel it while driving.Stu70 wrote: 29 Dec 2020, 00:18 Earnt my p80 stripes today , got my first dash squeak.
1999 V70 GLT
1999 V70 GLT
- BlackBart
Would the new “Bondic” plastic glue pens work for this? I just fixed three pairs of broken reading glasses. It’s a thick liquid you apply with a narrow tip, then you zap it with the blue UV light pen to harden it like epoxy in a few seconds. It came from dental filling technology.patcal wrote: 30 Dec 2020, 15:15Managed to break the drivers side turn signal tabs. Got new assemblies ordered.
Not sure what it’s structural properties are.
- Has thanked: 1611 times
- Been thanked: 4075 times
Deskinned two nice C70 seats for Evita
C70 have mechanical sips in 1999 and the seat leather upper is bayonet mounted at bottom va hog rings
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Had to replace the clutch hydraulic line, part 9181324 The old one had a single leak so I epoxied it while waiting for the new one to arrive. Well, that didn't work because it then sprouted 3 more leaks.
So we start taking the new line apart to ease installation. When removing this portion of the "easy disconnect/bleeder" from the car rotate clockwise 180 degrees to access the clip & remove it. Then give her a manly tug.
The actual line assembly has a bit of an origami/Tetris theme when trying to get it back into the airbox mount.
Then bleed the line. I regretfully admit that I didn't do it properly and will be doing so again in the coming week if all goes well. Just had to get the car back on the road before the incoming snow storm.
2023 Lexus RZ450e -66k
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Working on getting my new project 850 back together. Getting there. Lot of work over the last month! Doing suspension stuff the next few days as I wait for a new cam sensor to be able to start her up for the first time since I got it.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Has thanked: 317 times
- Been thanked: 531 times
Oh yeah, that looks MUCH better!
That clutch line makes me glad I live in NC... I have an original one from a '96 850 in my R and it looks practically brand new still
