upDATE5: 99 s70 silver awd turbo auto PARTS fs (bulk too), Antlers OK Topic is solved
weste46
Year and Model: 2004 XC70
Has thanked: 3 times
Been thanked: 2 times
Post by weste46 »
ETM received! Thanks!
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
weste46 wrote: 27 Feb 2023, 11:52 ETM received! Thanks!
:) you're welcome
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Just remembered this.
https://www.facebook.com/marketplace/pr ... 5003190461
Purchased a set of 4 complete door cards from Jonathan, if I recall last year for my Project 2006 S60 2.5T. He told me that he receives a shipping discount when purchases are processed through FB. We negotiated a price and he changed it on the FB page and like eBay went through with the transaction directly on FB. Shipped from Aurora IL to NC for $28. He purchase 2 large boxes and I think shipped using UPS.
May want to consider looking into this and selling to MVS members or others through a FB Marketplace Acct to receive what I consider a "FB Subsidized" shipping cost.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
CIK7 wrote: 23 Feb 2023, 11:33 Abscate I've ran into a hexa problem also known as the Allan screws that join shaft to rear differential. I tried a 6mm too big. 5.5mm to small. 1/4" too big. Next one down too small. Will you accept it if I cut the shaft close to the diff? Someone is bound to have the right tool.
As I suspected, stumbled across pics from the last time I had the pleasure of removing a P80 shaft;
I remembered right, red thread locker.
Heat plasticizes the locking goo, way easier to get them loose with a good 6mm allen.
This is what I use, smaller and much easier to get into tight spaces, really localizes the flame point
HF micro torch.jpg (59.82 KiB) Viewed 720 times
https://www.harborfreight.com/butane-mi ... 63170.html
CIK7
Post by CIK7 »
Bump
foggydogg
Post by foggydogg »
CIK7 wrote: 19 Mar 2023, 06:36Bump
Folks might not go back to the first post to see the update.
Has thanked: 1610 times
Been thanked: 4065 times
I’ll take some of those trim pieces off your hands. Will reach out on Pm. Crazy week at work and emptying apartments this week too, so hold until weekend please.
CIK7
Post by CIK7 »
I got sort of a torch. A direct blue flame candle lighter. Now I need to figure out the allan wrench. Perhaps cleaning out the head.
Has thanked: 2200 times
Been thanked: 1852 times
Soak the bolt heads with PB Blaster/Liquid Wrench or whatever, and then it is a laborious case of laying on your back and using a straight sharp pick, cleaning the allan heads out until the allan wrench fits nice and snug. You may have to tap it in with a hammer. I used a 3/8" drive allan socket and a wobble drive with a long brake bar on it. If you can reach the ends of the bolts make sure they are clean and lubed as well.
CIK7
Post by CIK7 »
scot850 wrote: 30 Mar 2023, 23:07 Soak the bolt heads with PB Blaster/Liquid Wrench or whatever, and then it is a laborious case of laying on your back and using a straight sharp pick, cleaning the allan heads out until the allan wrench fits nice and snug. You may have to tap it in with a hammer. I used a 3/8" drive allan socket and a wobble drive with a long brake bar on it. If you can reach the ends of the bolts make sure they are clean and lubed as well.
I forgot to soak most of them with lube. Got a light to shine on bolts while I unscrewed first one. There was no crud in the heads but #6 still did not fit. 5.5 was obviously too loose and 7 was obviously too big; 1/4" was also too big. However, I discovered that a T40 was perfect fit. Got all bolts out. Got the driveline bearing support and support plate unbolted. No matter how I wiggle the shaft in/out or even lowering the driveline support, the shaft will not come out from either end of the car.
