oil cooler line replacement
PCV System Repair on a Volvo 5-cylinder
Mecheng, I had the same issue you did reaching the torx bolt. In fact I stripped the torx head, much to my dismay. Basically, you have to remove the housing from the engine and then undo the torx bolt that holds the lines in. Even with universals, etc. I couldn't reach that damn bolt but it was easy once you removed the oil thermostat housing.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
i'm going to buy a 1/4" uv joint, my 3/8" didn't fit and an allen key torx, hopefully it works
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
mecheng
OK I got the 10mm bracket bolt out with the 1/4" uv joint.
For the torx 30, do I have to remove the thermostat? I tried with an Alex torx from underneath and threw the wheel well to no avail.... I'd rather not remove the thermostat
- 2216 Views
Last post by fitz548
- 16 Replies
- 7184 Views
Last post by erikv11
- 1537 Views
Last post by tryingbe
- 2790 Views
Last post by rguzz
- 1627 Views
Last post by SuperHerman
