Android Torque app for OBD2 volvos
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
He brings up an interesting point; air temp. I added two dials next to each other, one for outside temp and one for intake temp. It's incredible to see the two differences, especially when you stomp on it on a hot day. Makes you realize that cold air intakes really don't have much impact for their price.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
- Has thanked: 2856 times
- Been thanked: 1332 times
P80 factory air intake is surprisingly efficient (and lightweight). I went back to it after running a DIY piping setup. It's not high on the list of things to mod to get more power/mpg, but people often start there anyway.
Yeah - I just tried to watch my o2 volt readings while driving but that wasnt happening.
But at idle and revved to 2000rpm after I got back to my driveway - the o2 Volt charts for Bank 1 sensor 1 and 2 were basically identical sin charts. Not feeling good about that and need to do some research. Plus pending P0422 code - main catalyst efficiency below threshold.
On the fun side - I was not exactly racing but it calculated my 0-60 when I was merging on the highway at 22 seconds!
I might have to put a little more effort into that one next time.
1988 740 -- Long gone
1998 V70r -- Current daily driver
2004 S60 -- Magically turned into a Toyota Sienna
RollingStone
- Year and Model: 850 1994
Hey guys, I need your help again.
I got elm 327 clone (wifi) from amazon. I can use it with galaxy tab and Lumia windows phone. It works with most of the cars I've tried it on (saab 9-5 diesel, couple of renault clios, e46 m3,....).
I can't get it to work on my 97 850 T5. Adapter status in Torque app says, that it is connected to the adapter, and that the adapter can communicate with the ecu, but I can't get any readings, not even real-time readings, such as RPM and coolant temp.
I should mention that the ecu has been chipped (cheap ebay unit). Can this be a problem? Other than that, what could be wrong?
Thanks for the help.
Ben850
I believe the "cheap e bay unit" chip mod. bypasses the MAF. So that may be a problem.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- instarx
- Year and Model: XC70 T6 2011
- Has thanked: 1 time
You don't really need the phone part of a phone - just the android part. You can buy a used Android smartphone and simply never connect it to a phone service provider. Just use wifi for internet access. For this application you don't even need internet access because you will use bluetooth to connect the "phone" to the OBDII device (you will need wifi to download the app though). You can also just buy an android tablet for around $175 (and up) these days at Best Buy or Amazon. The advantage of a tablet is the screen is much bigger and you will be able to actually see the dials.rmmagow wrote:QUESTION!
I don't own a "smart" phone, I only use a Tracfone for emer use and phone calls. No, I'm not a luddite, just can find it in me to spend 75~100 a month for a smart phone service. That being said, this looks cool and I want to set this up for my cars. Can I just by an Android smart phone, say used and non network functional and use it to USB or Wi-Fi connect to this thing? Any way to get the App without having it subscribed to some service? Any other method for using either this system or others with a WiFi enabled device? My kid has an iPad, it only is usable off my home network, so, it is just WiFi. I'm assuming I can run this device or some other type via Bluetooth to it and use a Wifi connection at home to dowlload the application.
If I'm totally missing the boat here, explain to me in technical terms what I need to do. I understand most tech, just don't use a lot of it.
You can't use the ipad with this particular software because it isn't android, although there are probably similar iOS applications for it.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Sorry to hijack this thread but can anyone recommend a few good apps for the iPhone similar to Torque
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- BlackThunder
- Year and Model: 1997 850
- Has thanked: 6 times
- Been thanked: 3 times
I have found that this is a GREAT reason to hold onto your old phone when you upgrade your cell phone.
Torque has been great to me.
Dustin
Dustin
Dustin
2013 Volvo C30 T5
1997 Volvo 850 NA Sold to a New Volvo Enthusiast
2013 Volvo C30 T5
- osman
- Year and Model: 2002 c70 hardtop
+1BlackThunder wrote:I have found that this is a GREAT reason to hold onto your old phone when you upgrade your cell phone.
Dustin
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
Ben850
None of my phones were "smart" so I bought a small, used Galaxy tablet on e-bay.
- 70 Replies
- 96865 Views
Last post by xanthefin
- 1857 Views
Last post by lukasz22
- 897 Views
Last post by youngin9494
- 9055 Views
Last post by sleddriver
- 4049 Views
Last post by gamezonebull
