Parts failure poll: P2 Volvos: V70/S60/XC70 from 2001-2007
This topic is in the MVS Volvo Repair Database » Failed Parts Poll for P2 Volvos
What has failed on your P2 Volvo: V70/S60/XC70 from 2001-2007?
abs module
62
1%
ac compressor
62
1%
alarm system
126
3%
alternator
86
2%
axle shafts
95
2%
blower motor
66
2%
brake cylinder position sensor
18
0%
brake master cylinder
22
1%
broken ignition lock
26
1%
cabin switches
30
1%
catalytic converter
30
1%
cem (central electronic module)
33
1%
center console cover
65
2%
center console cup holder
62
1%
climate control fan
29
1%
climate system (including software upgrades)
26
1%
control arm bushings
177
4%
delaminated shoe on the parking brake mechanism
54
1%
discolored roof trim strips
113
3%
door whether strip
56
1%
engine cooling fan
29
1%
etm (electronic throttle module)
85
2%
exhaust flex down pipe
20
0%
exhaust pipe hanger broken (rusted, etc)
91
2%
front strut mounts
161
4%
front struts
146
3%
front window mechanism, slider or switch
76
2%
fuel pump
66
2%
fuel door hinge
123
3%
fuel door latch (not hinge)
84
2%
fuel tank pressure sensor
16
0%
headlamp ballasts (volvo calls them "Control units")
13
0%
headlamp leaky seal
38
1%
ignition coils
115
3%
ignition key failure (key replacement, programming)
13
0%
immobilizer antenna (start prevented error)
15
0%
lower ball joints
104
2%
lower torque rod
48
1%
oil sump seals
20
0%
other cup holder
28
1%
oxygen sensors
66
2%
parking brake cable
26
1%
passenger airbag sensor
6
0%
pcv system
123
3%
premature lightbulb/bulb socket failures
119
3%
radiator leak
79
2%
radio display
34
1%
rear view mirror
59
1%
rear bearing housing ("Knuckle")
6
0%
rear latch mechanism
27
1%
rear main seal
19
0%
seat controls cover
15
0%
seat motor
5
0%
siren control module
86
2%
spring clip to hold head light bulb
9
0%
spring seats
48
1%
steering rack
31
1%
steering wheel
4
0%
steering wheel controls
3
0%
sway bar links
135
3%
the turbocharger (whole thing)
17
0%
tie rods
128
3%
transmission (including software upgrades)
100
2%
transmission mount
93
2%
turbo valve
21
0%
turn signals
45
1%
upper engine mount
215
5%
vacuum pump/vacuum switch
18
0%
vvt solenoid
37
1%
water pump
29
1%
wheel bearings
98
2%
yaw sensor (anti-skid service required)
18
0%
Total votes: 4248
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
matthew1 wrote: 12 Jun 2024, 17:31 There are so many takeaways from this poll's data it's hard to organize my thoughts and write them all down, but I think my #1 takeaway is this: cars are heinously complex machines.
Mercedes cars of the same era are more complex. But Volvo info is much more available, especially here on MVS.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
upper engine mount is the winner, maybe because its the easiest to get at.
