Problem after transmission fluid change
Francois850
Year and Model: 97 850 Non Turbo
Re: Problem after transmission fluid change
Post by Francois850 »
erikv11 wrote:Not saying I would buy from here but here are the part #s
http://www.ipdusa.com/products/6603/113 ... r-oil-hose
http://www.ipdusa.com/products/6602/113 ... r-oil-hose
Thanks!!!! At least I have the part #, awesome!
Francois850
regent wrote:If this is your engine B5202FS, please see attached for parts.
If not, let me know exactly which engine you have (there may be a difference) and I will post a different PDF.
We'll make it fly again :D
Thanks
I have a 97 850 Non Turbo 20V Fuel Injected, so I believe it's a B5254S
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Then this is your case: (see attached)
Hope it helps
1997_850_NA Trans Cooling Arrangement-1.pdf
97 NA 850 Trans Cooloing
(111.68 KiB) Downloaded 104 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
Francois850
Hope it helps
Thanks! Nice chopper btw ;-)
regent
Post by regent »
Yea, thanks. Never had transmission problems like yours.
(Keep it low - don't tell anyone about it!) 8)
2015 BMW 335i
Francois850
regent wrote:Yea, thanks. Never had transmission problems like yours.
Well, it gets crazy hot in TX, especially the past 5 years, it's hard on those Swedish girls! :roll:
regent
Post by regent »
I wonder how much harder it can get with a modified cooling system :o
2015 BMW 335i
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
The cooler may have been disconnected for a reason. Sometimes we see the cooler start leaking into the radiator, making a huge problem - antifreeze destroys transmission bands. If you want to be absolutely sure, pressure test or change the radiator.
It's kinda sounding like proper pressures aren't building up within the transmission valve body. You used Dexron-III fluid, correct?
There's no flashing arrow or orange arrow lit up on the dash?
'98 S70 T5
2016 Chevy Cruze Premier
Francois850
jblackburn wrote:The cooler may have been disconnected for a reason. Sometimes we see the cooler start leaking into the radiator, making a huge problem - antifreeze destroys transmission bands. If you want to be absolutely sure, pressure test or change the radiator.
I replaced the radiator myself and that was after the transmission, put back the lines as they were, did not think about the trans back then as I had no issue. So, the radiator has low miles.
I used Mobil 1 after using DEX III / MERC as I was told it's better, made no difference. No, no flashing arrow, no CEL, no codes.
Francois850
regent wrote:I wonder how much harder it can get with a modified cooling system :o
can't be any harder.... run or die.
