98 T5 sluggish
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 12 times
Re: 98 T5 sluggish
Post by sleddriver »
Z06killinsbf wrote:Also, the one with the green clip looks impossible to get to with th turbo installed, or else I would have replaced it
I finally tackled this one from underneath when replacing the inlet turbo cooling hose. The original line had permanently bonded itself to the metal nipple. After sliding the green spring clamp back, I used a wood chisel to shave off a section of the lower hose. This revealed the nipple to be nearly an inch (20mm) long! No wonder I wasn't able to just pull it off.
I continued with shaving, then wedged off the remainder with a screwdriver.
M1 10W-30 HM
Z06killinsbf
Post by Z06killinsbf »
So did you put a clamp on the new hose?
1998 V70 T5
sleddriver
I did. New hose = 100% silicone.
M1 10W-30 HM
