Why I hate my 2000 V70R!
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
abscate wrote: 29 Oct 2017, 01:05
wizechatmgr wrote: 28 Oct 2017, 19:48 One never argues with female logic. To do so is suicide. =)
SWMBO: do you need gas?
Me: I can make it to the next gas stop
SWMBO: why not this one?
Me: do you need to stop?
SWMBO: No
Me: if an asteroid hits us in between, we will have saved the cost of an entire tank of gas.
SWMBO: Oh.
LOVE IT!!! :lol: :P :lol: :D It's so true Mike will run his truck empty, then after the gas light comes on he can go 30 more miles :roll: . I see the 1/4 mark and I feel nervous and fill the tank. I really never thought of a asteroid hitting in the mean time. Do guys really think strange things like that and somehow money will be saved. You can't ask directions either I'll bet....
June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Asking for directions is rewarded with 10 years of evap. leak codes and an intermittent oil leak... True story :)
Has thanked: 1610 times
Been thanked: 4068 times
I put this into google but I still don't understand what this means... please elaborate
June
Post by June »
abscate wrote: 29 Oct 2017, 08:28
Levity
My Volvo cars owned
1996 960 ordered
Sarcasm
If the 9-10 women who drive our fleet not one of them has ever seen the low gas light. I see it much less than I did when I was younger, which is just proof of Trainability.
In a more serious note running Volvos down to the light is bad for the fuel pump so the female logic is good advice here.
wizechatmgr
abscate wrote: 29 Oct 2017, 12:14 Sarcasm
Very true. That and the fact that in the middle of the night, not all gas stations are open in my part of the woods. Getting gas at 3 AM can be quite the adventure if you let the vehicle get down to the wire.
June
Post by June »
You are so right! We fill them by the 1/2 mark. 1/4 is as low as it goes unless extenuating circumstances. I was referring to Mike''s truck. V8 with the gas light on!!!!! I get real nervous because it's hot here most of the year (not that he would call AAA) but AAA takes 4 hours, or walk with the crazy drivers! June
My Volvo cars owned
1996 960 ordered
Our rule is 1/8 tank in summer, 1/4 tank winter is threshold for filling up
4 gallons will let you idle all night and stay warm if you are caught in a blizzard
Has thanked: 2202 times
Been thanked: 1852 times
Then there is the theory that not emptying and filling the tank from max to min, wears out the level sensor more quickly. Ask a P80 AWD owner with 2 of the suckers to replace and a full rear sub-frame and tank to drop (that is probably got rusted in mounting bolts) to get to replace them how great an idea that partial emptying of the tank goes. Also if you don't drain it regularly if you get water in your fill it will sit there. Fortunately the tanks are plastic!
Still agree with the 1/4 idea in the winter for safety at -40C!
June
Post by June »
scot850 wrote: 30 Oct 2017, 12:34 Then there is the theory that not emptying and filling the tank from max to min, wears out the level sensor more quickly. Ask a P80 AWD owner with 2 of the suckers to replace and a full rear sub-frame and tank to drop (that is probably got rusted in mounting bolts) to get to replace them how great an idea that partial emptying of the tank goes. Also if you don't drain it regularly if you get water in your fill it will sit there. Fortunately the tanks are plastic!
I never thought of that! So by running the tank to empty and then filling it wears the sending unit out? Mostly I refill before 1/4 is reached, do you think that's too low and might cause the sender to fail early? I was always told that between 1/2 and 1/4 the fuel pump can get hot causing early fuel pump failure.
Maybe twice a year I run the tank until the light comes on but a strange thing happens when I run it low. Suddenly the light goes out and the needle rises for a while before going down and the light comes back on again. Sort of like some small reserve tank refills a couple of gallons. I can't explain it. June
My Volvo cars owned
1996 960 ordered
