What happens if you over fill when you do the flush?
Tried this, had great and noticable effect and drove for 200miles after, but I believe I over filled by quite a bit...
New Modified Transmission Flush Method with Pictures
- Has thanked: 17 times
- Been thanked: 35 times
It will push out the dipstick tube and make quite a mess...besides that, it could be a fire hazard. I read this on another forum: "When they are overfilled cold, and then run to normal operating temperatures, the fluid expands and can run out the filler tube or dipstick tube. In this case (a truck that was under investigation by an insurance company for catching fire) it dripped down onto the very hot catalytic converter, and then caught fire." I've also read this on yet another forum but never had confirmation: "A tranny depends upon pressure against one side of myriad valves and parts with no fluid and/or fluid pressure against the other side to properly move and apply proper pressure."
At any rate, don't know how similar our transmissions are to the above, but I wouldn't want to take any chances.
In your case, if you did over-fill, either take the plug out from below for just a few seconds (a messy hand will be all you experience) or use some tubing and suck some out of the dipstick hole. You can always add some back later if you take to much out.
forbesmarch
- Year and Model:
But I'm not likely to blow the seals... right?
JRL
- Year and Model: Several
- Been thanked: 16 times
It's not good at all!
Drain out the excess ASAP
Thanks for all your help. The flush went fairly smoothly and I was quite proud of myself after completing the job!
A couple things I might add (for an '02 s60):
Another tool you will need (and this is probably a 'no-duh' to you guys) is a 12mm socket to remove the skid plate to gain access to the tranny plug.
Also, 3/4" OD may be too small to recieve the fluid out of the radiator. The tube I got (from a gardening store) was 3/4" inside diameter and was still very difficult to stretch around the pipe. I had to cut a little slit in it to make it fit.
FYI, I have a 2000 S70 and just sucessfully completed MadeinJapan flush method--everything worked as described--thanks for making it easy for us part time mechanics. Mine had a green clip on tranny hose also, and fluid flushes out of the hose as described (i.e. attach the 1/2" inside diameter hose over hose you remove).jar240 wrote:I went to start the flush and noticed my 2000 V70 has the green clips on the trans hoses at the cooler/rad. does this mean I have the reverse flow direction as with the P2's? Is there a way to tell without pulling the hose and starting the engine?MadeInJapan wrote:Important- Please Read This First (Info for P2 Cars):
...the newer (P2- or '01 on) Volvo's transmission fluid flows in the opposite direction. In other words, when you take the tanny-to-radiator line off, you actually let the tranny flush out of the upper hose connection on the radiator with the newer Volvo's unlike what is written below (therefore
Thanks,
Chris
Jim Davis
If anyone gets to the end of this thread by some chance and are not aware that pictures were added recently with the original write-up (lost in the transfer to the new site), go back to page 1 and check it out.
-MIJ
-MIJ
Can I just use any dextron III fluid from walmart to flush my AT transmission on my volvo 850?
I dont wona spent $90 doll for mobil 3309
I can do it for $40 buing just ordinary DextronIII
Em I going to damage my transmission if I buy castrol?
chuckcintron
- Year and Model:
I've been using Valvoline ATF for the last 60,000 miles...I flush every 30,000. I think unless you are towing or putting some other real demands on the tranny a cheaper (but good quality) fluid is just fine, along with a periodic flush routine.
Just my opinion.
-Chuck
Just my opinion.
-Chuck
1997 855GLT
- 2995 Views
Last post by Pezgoon
- 1581 Views
Last post by Turbo_Boss
- 1294 Views
Last post by matthew1
- 14 Replies
- 4975 Views
Last post by firstv70volvo
- 1649 Views
Last post by MoVolvos
