I use different method to flush the ATF 3.2 What you think?
Turbo_Boss
Year and Model: 2008 XC90 3.2AWD
Has thanked: 12 times
Been thanked: 2 times
Post by Turbo_Boss »
Hey Guys,
Please check my post here with pics.
https://www.freel2.com/forum/topic34996.html
Rgds
Isaac
2008 VOLVO XC90 3.2L AWD
2008 TOYOTA Prado 2.7L 4x4
2009 VW Jetta 2.0
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
That has been around for a long time and it has a name, Google "Gibbons method" .
Active
Past
Turbo_Boss
RickHaleParker wrote: 26 Jan 2020, 00:46 That has been around for a long time and it has a name, Google "Gibbons method" .
On Gibbons method, you have to remove the Air Filter Housing to get access to the Filler Plug hole (Torx 55) that is on top of the transmission housing........ Then you have to lower a funnel into that filler hole to filled new ATF fluid.
My method avoid all of these.............. I use the return pipe/hose that is connected on the top part on the radiator to filled new ATF fluid
Sisssssxxxxxxn título.jpg (64.91 KiB) Viewed 1420 times
2009 VW Jetta 2.0
