'03 s60 needs good engine shop
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
WD-40 is completely useless as a penetrant, it will not help at all. PBBlaster or Liquid Wrench sure, or homwbrew acetone + ATF etc.
stephansvolvo
Year and Model: V70 GLT 1998
Has thanked: 21 times
Been thanked: 3 times
Post by stephansvolvo »
Yeah. I’ve hammered that thing with PB and my impact that thing isn’t budging. I guess I’ll just have to deal. I have one last ditch effort.
I was thinking oil coolant fill drain refill the beautiful milky sludge of coolant and oil mix!!!’ Ole!
Thank you for your help. I need this car out of my garage so I can get another one back in. Geesh.
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
Has thanked: 1611 times
Been thanked: 4075 times
I crack the crank bolt off before Removing the timing belt, using a 1/2 inch impact rated at about 550 ft lbs
stephansvolvo
abscate wrote: 15 Apr 2021, 04:40 I crack the crank bolt off before Removing the timing belt, using a 1/2 inch impact rated at about 550 ft lbs
I’m not sure my little 1/2 inch has that much torque. I tried everything.
I remember reading that from your recommendations. Is it lefty loosey?
Stephan
98 S70 GLT
73 IH Scout ii
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
stephansvolvo wrote: 15 Apr 2021, 09:17
Are you using an impact socket? The thinner wall regular sockets don't transfer as much impact force. They even make a super thick wall socket for Honda crank bolts (won't fit Volvo crank nut though), which are very difficult to remove even with the strongest impact wrench.
Post by erikv11 »
Along those lines ... I don't know if it's in the budget but this cheap-o corded tool would outperform a typical home air tool setup costing much more and probably be the last impact you ever needed, assuming you don't have to get into tight places with the tool https://www.harborfreight.com/85-amp-co ... 64120.html
I've got one with less torque that has never met an axle nut or crank nut it couldn't spin off. I basically use my air gun until it gets overmatched then get out the electric one for those one or two stubborn fasteners.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
these cheapo roadside impacts are surprisingly effective, they spin up to max rpm before impacting.
Its the first smack of the anvil that counts.
