And now the alarm just went off, out on the street at 7:30AM. But of course no flashers.....
The fob button does nothing, so I just unlocked the drivers door.
2004 XC70 Instrument Cluster Issues
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Xemodex has just emailed me a link to a warranty claims form.......
- BlackBart
Alarm went off again. I went out and pulled the DIM. Power connection looked normal, all wires in their slots - it’s never been out of the car before this.
The alarm windshield light is still blinking (?)
And I believe I can’t unlock the rear hatch to disconnect the battery.
- BlackBart
I can't picture how fuses could cause all of this stuff. Do you know which would be the relevant fuses and where? There are three fuse panels on this car I believe - engine compartment, under the dash, and LR side panel, correct?
- DonnVa
- Year and Model: 2005 XC70
- Has thanked: 21 times
- Been thanked: 61 times
I was just getting you to double check everything. I work in electronics (not automotive) and when I install a new or refurbished part in a medical instrument and get a different set of symptoms the first thing I do is double check my work. I make sure I installed it properly and look to see if I bumped something causing it to be disconnected, etc. I was grasping at straws when I said check fuses and voltage. You said you got a complete DIM and you sent them just the circuit board, are you sure you didn’t get someone else’s DIM? Grasping at straws again… If you got the right part and everything is good w/ your install, it sounds like a warranty issue.BlackBart wrote: 02 Sep 2022, 08:37 I can't picture how fuses could cause all of this stuff. Do you know which would be the relevant fuses and where? There are three fuse panels on this car I believe - engine compartment, under the dash, and LR side panel, correct?
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
Many of the problems you're seeing are related to the CEM and it could be because of the DIM and the low speed bus but it's worth checking the fuses related to CEM power, Check fuses 14, 22 and 32 in the passenger compartment, left side of dash. Fuses 22 and 32 supply 12V to the CEM at all times so check the 12V level with these two fuses pulled too. For fuse 14, 12V is switch on when the ignition switch is in position I, check this fuse and check for 12V with this fuse pulled and key in position I.BlackBart wrote: 02 Sep 2022, 08:37 I can't picture how fuses could cause all of this stuff. Do you know which would be the relevant fuses and where? There are three fuse panels on this car I believe - engine compartment, under the dash, and LR side panel, correct?
Some of the problems you're seeing are not related to the low speed bus so this seems more CEM related only but I could be wrong. The fog lights and headlight knob use a single serial communication line to the CEM, not the low speed bus so I would expect the fog lights and headlight/parking light knob to work even if there's problem with the DIM.
- BlackBart
No no, I appreciate the advice. Just trying to understand this. The story is my DIM just quit. I made a valiant attempt to reflow it - no dice. Sent it (bare) to Xemodex. They said it would be easier to send me a completed one off the shelf, so in theory I got a tested refurbished DIM including a complete enclosure with gauges and dial pointers. So whatever was wrong with mine should be eliminated by that process.DonnVa wrote: 02 Sep 2022, 11:38I was just getting you to double check everything. I work in electronics (not automotive) and when I install a new or refurbished part in a medical instrument and get a different set of symptoms the first thing I do is double check my work. I make sure I installed it properly and look to see if I bumped something causing it to be disconnected, etc. I was grasping at straws when I said check fuses and voltage. You said you got a complete DIM and you sent them just the circuit board, are you sure you didn’t get someone else’s DIM? Grasping at straws again… If you got the right part and everything is good w/ your install, it sounds like a warranty issue.BlackBart wrote: 02 Sep 2022, 08:37 I can't picture how fuses could cause all of this stuff. Do you know which would be the relevant fuses and where? There are three fuse panels on this car I believe - engine compartment, under the dash, and LR side panel, correct?
There's an 8.5x11 "DIM Diagnostics" test (?) sheet which tells me nothing. Looks like a grab from someone's screen.
- BlackBart
Where physically are you checking for 12V? At either side of the fuse holder?firstv70volvo wrote: 02 Sep 2022, 11:42Check fuses 14, 22 and 32 in the passenger compartment, left side of dash. Fuses 22 and 32 supply 12V to the CEM at all times so check the 12V level with these two fuses pulled too.
- firstv70volvo
On one side of the fuse contacts with the fuse pulled, not sure which side but one contact should have 12V when the fuse is pulled.BlackBart wrote: 02 Sep 2022, 12:01Where physically are you checking for 12V? At either side of the fuse holder?firstv70volvo wrote: 02 Sep 2022, 11:42Check fuses 14, 22 and 32 in the passenger compartment, left side of dash. Fuses 22 and 32 supply 12V to the CEM at all times so check the 12V level with these two fuses pulled too.
- 679 Views
Last post by chrism
- 5019 Views
Last post by oragex
- 5726 Views
Last post by sergio
- 6301 Views
Last post by waffleshill
- 1136 Views
Last post by enotslim
