Good, I'm not the only one that hears those voices.abscate wrote: 21 Apr 2021, 02:29 Next come the voices........buy another Volvo.......buy another Volvo.....
- Has thanked: 317 times
- Been thanked: 531 times
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
My 850 decided that 1800 hrs after work was the perfect time to brick a fuel pump. After much tapping it did eventually unstick and let the car run, but I was faced with the dilemma of how to get it home.
My breakdown cover has free recovery within 50mi, but my commute is 78mi. I'd have had to pay a flat fee of £120 and then £2 per mile for the last 28 miles (or £180). Not super expensive, but the nearest flat bed was over 2 hours away so I wasn't hugely keen.
The next option was to tow it to a local independent Volvo specialist. They had closed, however, so I'd have had to leave the car in the driveway with the keys in the car for 16 hours until they reopened....on an industrial estate...so I glossed over that method.
Final option was just to gamble that once running it would keep running, and drive it home. I chose to gamble. Fairly nerve-wracking given there are no hard shoulders at any point on my commute, especially when I could hear the pump change frequency and occasionally stop for a split-second.
Ordered a Walbro GSS342 when I got home, and will hopefully fit that this weekend. Is a pair of screwdrivers the best option for the push fit fuel lines or?
Had to borrow a relatives Subaru XV to commute in today. Horrid. Rattly, noisy, the gearing is illogical, seats are uncomfortable, there's no thought of ergonomics in the interior design, and the steering (whilst nicely weighted) is so utterly devoid of any feedback that you have no idea what the wheels are doing. Capable chassis and suspension though, I'll give it that.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Oh boy, this kind of brings back memories of my old 97' 850 GLT and when the fuel pump quit on a busy interstate highway during rush hour - fun times. The failure was preceeded by a whining pump, but I thought I had a couple of days to get to it. Turned out to be a false assumption.Cookeh wrote: 22 Apr 2021, 02:45 My 850 decided that 1800 hrs after work was the perfect time to brick a fuel pump. After much tapping it did eventually unstick and let the car run, but I was faced with the dilemma of how to get it home.
In any case, these are very easy to change. Screwdriver will do just fine to pry the fuel lines off, just like you say.
Glad you made it home okay that day,
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
My cousin's 240 did this a couple times in 95 degree weather on the highway during rush hour... we were cruising around with our other cousin who was visiting and the fuel pump started to get weak, then gave out. We had to wait for it to cool down for the pump to function again... which got us another 7-8 miles... then eventually we got the car home. Fun times in nasty, humid NC heat!
- Has thanked: 1613 times
- Been thanked: 4078 times
Lumber hauler
- Has thanked: 987 times
- Been thanked: 1078 times
Tell us about your building project.
I’m building an underground garage to protect my Volvos from the Apocalypse
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
We should definitely make that a sticky....abscate wrote: 23 Apr 2021, 08:21 I’m building an underground garage to protect my Volvos from the Apocalypse
New latch and rear panel for my 850 Wagon tailgate. Got the latch from salvage yard. The rear panel was loose and the previous owner did some kinda hack job on it and added glued velcro strips so I replaced it and also bought the IPD panel repair kit. Now the rear of the car doesn't rattle annoyingly and the key mechanism works.
Next up is the ignition switch replace so I don't have to wiggle the key to some magic position in order to get the car out of park as well as install of a turn signal arm so the turn signal auto shut off works again.
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Price of framing lumber has skyrocketed lately. Maybe you found that out.
