dustyou
Year and Model: 98 s70
Has thanked: 1 time
Re: What did you do to your Volvo today? (now Sticky!!)
Post by dustyou »
Repair to the 1 Inch hose under the throttle cover which is on that stack of vacuum ports most of which are capped, this thing flies now! Omg.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
dustyou wrote: 15 Feb 2018, 16:59 Repair to the 1 Inch hose under the throttle cover which is on that stack of vacuum ports most of which are capped, this thing flies now! Omg.
They're supposed to be capped, I think there's only one that's actually used. I bet your idle is smoother now with the idle air valve hose repaired!
Has thanked: 1502 times
Been thanked: 3817 times
Rolled 700 miles this week in the 1999T5 third " century" ( broke 200,000k miles last week) ...rolled NY BOS PVD PHL
The P80 seat worked its usual magic
Met some really interesting astrophysics people
Replaced front right ABS sensor. Sometime I had repaired this from a break between the straun relief
Used a Delphi from FCP, fit perfect
M6 to release sensor from hub
Two attaches and two clips to harness
Cleared P1550 and spurious P0137
ABS light cleared in self test
Mileage 200,937
dustyou
Has thanked: 1 time
Post by dustyou »
bmdubya1198 wrote: 15 Feb 2018, 18:33
it idled fine. one is used. now the turbo works. it didnt. owned car for 2400 miles now. no codes. stage 0 i presume.
bmdubya1198
Picked up some rear floor mats and a driver's seat switch at the 'yard today. I can finally move my seat forward! And the memory settings work!
Probably gonna need to go back tomorrow for a blower motor resistor for my Saab and to grab a taillight for somebody's 960.
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
bmdubya1198 wrote: 15 Feb 2018, 07:44
wizechatmgr wrote: 15 Feb 2018, 06:40 Replaced the upper radiator hose with a silicone hose and some new ABA clamps. Interestingly enough my temps went down one tick on the instrument cluster. The old hose was most definitely in need of replacement and had some minor to serious swelling.
The next warm day I may conquer the lower hose and turbo/heater hoses.
I definitely recommend getting to the other hoses as soon as you can if they're getting soft or swelling. My cousin and I made the mistake of changing his expansion tank hoses and radiator hoses to silicone without changing his heater hoses, which were already pretty soft. Heater hose blew out two days later.
Then his radiator went a couple weeks later. Fresh fill of $40 Volvo blue coolant too...
That's the plan once the weather is a bit more manageable.
bmdubya1198
wizechatmgr wrote: 18 Feb 2018, 07:03
Yeah, not the most fun in the cold! I’m enjoying these 60-70 degree sunny days here in NC!
I did a wheel off ABS sensor in the driveway Saturday..about 25-30F but dry and sunny.
Good 7 mil gloves and work gloves are key
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
abscate wrote: 15 Feb 2018, 09:11 Fixed my headlight wipers with ProParts - some issues with fitting.
Gathered up all my spares and pinged Dirk
Nice! Did you have to access the wiper motor? I bought ProParts replacement arms when they started to fall apart but never managed to get the old ones off.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
