- Has thanked: 317 times
- Been thanked: 531 times
They're supposed to be capped, I think there's only one that's actually used. I bet your idle is smoother now with the idle air valve hose repaired!dustyou wrote: 15 Feb 2018, 16:59 Repair to the 1 Inch hose under the throttle cover which is on that stack of vacuum ports most of which are capped, this thing flies now! Omg.
- Has thanked: 1611 times
- Been thanked: 4075 times
Rolled 700 miles this week in the 1999T5 third " century" ( broke 200,000k miles last week) ...rolled NY BOS PVD PHL
The P80 seat worked its usual magic
Met some really interesting astrophysics people
Replaced front right ABS sensor. Sometime I had repaired this from a break between the straun relief
Used a Delphi from FCP, fit perfect
M6 to release sensor from hub
Two attaches and two clips to harness
Cleared P1550 and spurious P0137
ABS light cleared in self test
Mileage 200,937
Mileage 200,937
dustyou
- Year and Model: 98 s70
it idled fine. one is used. now the turbo works. it didnt. owned car for 2400 miles now. no codes. stage 0 i presume.bmdubya1198 wrote: 15 Feb 2018, 18:33They're supposed to be capped, I think there's only one that's actually used. I bet your idle is smoother now with the idle air valve hose repaired!dustyou wrote: 15 Feb 2018, 16:59 Repair to the 1 Inch hose under the throttle cover which is on that stack of vacuum ports most of which are capped, this thing flies now! Omg.
Picked up some rear floor mats and a driver's seat switch at the 'yard today. I can finally move my seat forward! And the memory settings work!
Probably gonna need to go back tomorrow for a blower motor resistor for my Saab and to grab a taillight for somebody's 960.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
That's the plan once the weather is a bit more manageable.bmdubya1198 wrote: 15 Feb 2018, 07:44I definitely recommend getting to the other hoses as soon as you can if they're getting soft or swelling. My cousin and I made the mistake of changing his expansion tank hoses and radiator hoses to silicone without changing his heater hoses, which were already pretty soft. Heater hose blew out two days later.wizechatmgr wrote: 15 Feb 2018, 06:40 Replaced the upper radiator hose with a silicone hose and some new ABA clamps. Interestingly enough my temps went down one tick on the instrument cluster. The old hose was most definitely in need of replacement and had some minor to serious swelling.
The next warm day I may conquer the lower hose and turbo/heater hoses.
Then his radiator went a couple weeks later. Fresh fill of $40 Volvo blue coolant too...
2023 Lexus RZ450e -66k
Yeah, not the most fun in the cold! I’m enjoying these 60-70 degree sunny days here in NC!wizechatmgr wrote: 18 Feb 2018, 07:03That's the plan once the weather is a bit more manageable.bmdubya1198 wrote: 15 Feb 2018, 07:44I definitely recommend getting to the other hoses as soon as you can if they're getting soft or swelling. My cousin and I made the mistake of changing his expansion tank hoses and radiator hoses to silicone without changing his heater hoses, which were already pretty soft. Heater hose blew out two days later.wizechatmgr wrote: 15 Feb 2018, 06:40 Replaced the upper radiator hose with a silicone hose and some new ABA clamps. Interestingly enough my temps went down one tick on the instrument cluster. The old hose was most definitely in need of replacement and had some minor to serious swelling.
I did a wheel off ABS sensor in the driveway Saturday..about 25-30F but dry and sunny.
Good 7 mil gloves and work gloves are key
brunocerous
- Year and Model: 1998 V70
- Has thanked: 303 times
- Been thanked: 43 times
Nice! Did you have to access the wiper motor? I bought ProParts replacement arms when they started to fall apart but never managed to get the old ones off.abscate wrote: 15 Feb 2018, 09:11 Fixed my headlight wipers with ProParts - some issues with fitting.
Gathered up all my spares and pinged Dirk
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
