EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
Pull up your dipstick (1 cm?) to releave PCV pressure until you do the PCV job.
- Antoine240bk
- Year and Model: XC70 2.5T-2006 - 4C
- Has thanked: 12 times
- Been thanked: 30 times
I will put notes on this thread once i'll start the PCV job. I see that FCP have all the kit needed.abscate wrote: 14 Apr 2019, 05:42 There’s an improved one that doesn’t cough out the pin and ruin your engine. I’ll try to find the thread with all the part numbers to confirm.
viewtopic.php?f=9&t=85431&start=20
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Pulled from the junkyard a set of aluminum door trims from a T5, going to install them with my tan interior. Also got a set of rear tweeters from an XC70, these are going into the front doors near the main speakers, at the second grid opening (this grid is used for the premium double speakers). These XC70 rear pillar tweeters (sit right near the trunk lid) are beefy and much larger than even the premium front tweeters.
- Untitled.jpg (94.68 KiB) Viewed 1968 times
- Has thanked: 2856 times
- Been thanked: 1332 times
Oragex, I split off your seat video post into P2 seat information, how to ID, what to look for, and comfort opinion.
It's too good not to! Here's the video for those who don't want to follow the link above:
- ndphotonl
- Year and Model: 2001 S80 2.4T
- Has thanked: 27 times
- Been thanked: 33 times
Bought and fitted the so called HD TCV, which is basically a Pierburg unit with type nr: 7.22908.03.0 . Its used in Porsches & Rovers. I noticed positive change, especially with partial throttle. Recommended update if you have a tired TCV!
Volvo S80 2.4T Pierburg TCV 7.22908.03.0 by Andy Ramdin, on Flickr
Volvo S80 2.4T Pierburg TCV 7.22908.03.0 by Andy Ramdin, on FlickrVolvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
- bepilot
- Year and Model: 2001 S60 2.4T
- Has thanked: 2 times
^^ will keep this one in my reminders, dankjewel!
I changed my lava lamp rear view mirror with one of a ‘14 xc90, it was a bit of diy but it works!
2001 S60 2.4T manual
It's not 'tuning' we're after, it's 'continuous improvement'...
- oragex
Two videos with the fast idle and the sunroof drains cleaning - in particular in the second video I talk how my side airbag got wet because of a clogged sunroof drain
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Ruby Red 2004 XC70 got new front lower control arms (Lemforder), ball joints (Lemforder), front rotors (Zimmerman) and pads (Akebono ceramic). I think the front calipers are tired and need to be changed as well.
Have sway bar end links and outer tie rod ends that need to be done as well, but we ran out of time. The struts and related hardware had been done 10 k miles ago.
As of now, I am pretty far along on the $5,100 worth of work the dealer told the prior owner it needed. (Not surprisingly for far less than $5,100.)
I have the CTA ball joint tool that I am thinking of making an MVS loaner now that mine are done. Air hammer was pretty much a necessity to do the ball joints, but it does ding up the knuckle a bit.
Sway bar end links went on today (Lemforder).
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
