- Has thanked: 1505 times
- Been thanked: 3818 times
Spray paint with LiquidSteel (tm) and you are done!
- FireFox31
- Has thanked: 158 times
- Been thanked: 300 times
How will that be as strong as the original metal part? I'd feel more comfortable milling a crude yet effective one out of metal at a machine shop.
FireFox31
- Has thanked: 304 times
- Been thanked: 517 times
That's just a model, I believe. The final product will likely be made of aluminum/steel.
- Has thanked: 927 times
- Been thanked: 1000 times
Potential marketable product here for the engine mount.
- Nevada1906
- Year and Model: 1995 850 Turbo
- Been thanked: 30 times
bmdubya1198 wrote: ↑14 Sep 2021, 12:02That's just a model, I believe. The final product will likely be made of aluminum/steel.
It's an input model that'll be the basis of the actual mount made from 1/4" steel plate. It doesn't fit EXACTLY, which is the reason I built it. I need to space out the lower bolt holes another 1/16" or so front to back.
I have to get another argon bottle for my MIG welder and I can build the service piece.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
- Nevada1906
Possibly, might even be a set - who knows? Right now, I need a way to physically mount the engine in the chassis and this is it.volvolugnut wrote: ↑14 Sep 2021, 12:26 Potential marketable product here for the engine mount.
- Has thanked: 1848 times
- Been thanked: 1710 times
Excellent work and best of luck getting to the finished part. Maybe a new side-line job here? Wouldn't be the first to do so on MVS taking a hobby to a full time job!
- Nevada1906
Thanks! Always nice to know people like my work.ZionXIX wrote: ↑13 Sep 2021, 20:35Nicely done sir! Cant wait to see the final product.Nevada1906 wrote: ↑13 Sep 2021, 20:26 Here's a tip for anyone who wants to take a run at swapping an S60R engine into an 850: At least one engine mount doesn't line up.
This is the front mount from the 850's B5234T. As you can see, not only is the bolt pattern wrong, but the bolts themselves won't fit the old mount. Luckily, there's a solution.
I took some measurements for a new mount, built it in Rhino and output the file to the resin printer.
And voila. This is a quick-and-dirty template for the actual 1/4" welded steel engine mount, fully compatible with the stock cushion mount.
And it fits nicely, too.
- Nevada1906
Thanks!
Of course, I've gotta test it first. This is a Rev 1, after all.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 336 times
The stock P80 RN front engine mount does work (99-00 S/V/X70 (and I assume the 99-04 C70)) in this instance. If you can find one.Nevada1906 wrote: ↑13 Sep 2021, 20:26 Here's a tip for anyone who wants to take a run at swapping an S60R engine into an 850: At least one engine mount doesn't line up.
As someone who built and sold custom motor mounts (other applications) for 15 years, I applaud your work. If you're planning a weldment as a final piece, you can use your printed example as a basis to build your weld-jig.
