Climate Control Nightmares Topic is solved
Chassis break is in the 1999 year but ECC 1999 is different than 1998. You probably need a 98 donor
- Has thanked: 2199 times
- Been thanked: 1851 times
I knew there was a change in 98-99 in the ECC, never heard of one on the servo motors though? Checking on Volvo websites they list the same motor from 93-04 on P80's. Yes the ECC units are different, and the blend motor on a 99 has a weird looking plastic round maze attached to the same motor. There are part number changes over the years, but I have used random ones from my stash on different year cars with no issues.
In 1999 the two blend door on the driver side was melded into one with a Rube Goldberg cam linkage , I believe?scot850 wrote: 17 Nov 2023, 20:01 I knew there was a change in 98-99 in the ECC, never heard of one on the servo motors though? Checking on Volvo websites they list the same motor from 93-04 on P80's. Yes the ECC units are different, and the blend motor on a 99 has a weird looking plastic round maze attached to the same motor. There are part number changes over the years, but I have used random ones from my stash on different year cars with no issues.
Maybe the motors are the same, though?
Motors are the same. The plastic part is held on by a screw I think I recall. It all comes off to leave the same motor below. Just to be sure, I will double check the part numbers.
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
I thought the motors were the same too, but motors out of my ‘99 parts car (that worked fine when the car last got driven) refused to work in my ‘98. Put in a motor out of a ‘98 part out and it worked great.
The ECC out of a ‘99 will make a ‘98 power cycle with the key on. No bueno. You need a ‘98 module in a ‘98 car.
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
- 810 Views
Last post by GreldonSilverhand
- 11 Replies
- 6763 Views
Last post by maxi948
- 3895 Views
- 2025 Views
Last post by brendonrobar
- 3481 Views
Last post by caliwagon
