1990 740 gle gas delivery problem?
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
I permanently installed an A/C Schrader valve in the fuel rail inlet tube on my 1988 760 Turbo using a brass tee and compression fittings.
1988 Volvo 760 Turbo Wagon
Great idea, think I'll try it, it probably isn't enough pressure, about the only thing left I haven't checked, was getting the 02 code, gotta get one of those I guess, I try hard not to but still end up throwing parts at it.
lummert
To install a schrader valve in the inlet tube one must cut off the fitting on the end of the tube, drill and tap the hole in the fitting for 1/8" NPT. The compression fitting is 5/16" on one end and 1/8" NPT on the other. The schrader valve is for R-12 A/C. One compression nut is placed on the tube followed by the ferrule. The fitting is installed into one end of the tee. a 1/8" NPT short nipple goes in other end of tee. the modified fitting that was removed is installed on end of short nipple. Fuel hose connects to the rail fitting as before. Schrader valve installs in side of tee. Use teflon on all pipe threads.
Wow, didn't realize there were so many steps, I'm pretty sure I would mess up somewhere. Think I'll try the fused jumper on the fuel pump relay, to see if it stays running for longer than a few minutes, wonder what gauge wire should I use, did you use a regular 30 a car fuse or a different kind of 30 a fuse on yours?, thanks.
lummert
This would result in a longer time before going to closed loop.joedrt77 wrote:Anyone have good results, with a universal one wire o2 sensor on these? thanks.
It's back to starting for about 1 second on starting fluid, new cps, new power stage, tested or bypassed both relays, 12 v. at coil, 11.95 v. at f i connector, going for new spark wires next, going to try to test fuel pressure, if it's possible without a schrader valve.
- 29 Replies
- 5048 Views
Last post by 93Regina
- 2188 Views
Last post by lolafiona73
- 11 Replies
- 2048 Views
- 402 Views
Last post by cn90
- 1112 Views
