AW55-50SN woes-easy to repair? Topic is solved
This topic is in the MVS Volvo Repair Database » Repairing a AW55-50SN Transmission in a 2001 V70
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
We had an AFL premiership match yesterday. The 'roos (North Melbourne) were knocked out and didn't make the finals.
The Tigers (Richmond) were the victors so I'd better watch out for night stalking cats.
Wife promised she would be my pace car tomorrow.
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
You're saying you pushed the filter screen out and possibly up into the transmission or poked a hole in it? That sounds like Trouble. The objective would be to find a way to clean/clear the debris from the screen without needing to pull the transmission. Not effectively bypass or remove the filter. Larger particles this screen is designed to block will likely cause problems -- accelerate wear of the frictions, cause problems in the valve body/solenoids etc.
The line you blew into I believe is the return line that would drain back to the pan (not back flow through the pump/filter). In the flush DIY videos I've seen where people run the engine and pull 3L at a time they get the old fluid out through a tube inserted into the radiator side of that connection with a makeshift seal around a tube. So by that metric I think you need to pressurize the port on the radiator to backflush through the pump or disconnect the other hose down below and blow or run solvent/suck fluid through that. People usually access the system via at the top connection because the lower one is difficult to access without removing other stuff. Someone correct me if I'm wrong.
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Precopster can if he wants to put 2 filters inline. One on each transmission line from / to the radiator. Then the fluid will be like pure. Plus the filter does not catch all the debris.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
precopster
You can't clear the filter without removing it. If you can find a way please share it....do please!!
I didn't use a camera but from what I can feel the filter is out of the way.
I'll take my chances with a Magnefine replaced every engine oil change rather than a filter I'm not certain I cleared properly because I can't see it.
precopster
5 kms and counting. We're at a shopping mall in convoy.
mbrian200 I didn't blow air into the
return line. I blew air into the radiator port it belongs to effectively pushing crud off the bottom of the filter and into the sump area. I used nylon hose with electrical tape to provide a seal with the radiator port.
When back flushing the filings with fluid I used the return line which lead straight to the hole I drilled or within a few inches.
precopster
11kms and still driving well. The 1-2 shift feels softer than it used to.
All other shifts are perfect.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
precopster wrote: 01 Oct 2017, 23:41 11kms and still driving well. The 1-2 shift feels softer than it used to.
If this works you guys will get the volvo medal of honor. If not....well we told you it won't.
precopster
Cuhfs it was your idea. You can have the credit on this one.
Or the blame if it doesn't :D
cuhfs
Post by cuhfs »
I think this was a partnership. You did the surgery. I hope it worked and car is back on road for daily use.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
Has thanked: 1610 times
Been thanked: 4065 times
You need to invoke the Wall Street model , cuhfs......take the rewards of the risk, but tell the public they have to pay for the failures.... :-)
I hope the Tigers did better than Crystal Palace is doing....
