The NEW (2018) BLOOPERS AND BLUNDERS THREAD
- Has thanked: 316 times
- Been thanked: 531 times
Ouch!
volvodork
- Year and Model: 2001 X/C 70
- Has thanked: 1 time
- Been thanked: 3 times
Installing a rebuilt 351 Windsor into my son-in-law's 1994 Ford F-150 (replaced the blown 302 motor) and would crank but no-start. Went round and round banging my head trying to figure out what I'd missed (I've rebuilt a couple Ford motors before) even pulled out distributor a couple times to check if 180 out, firing order, etc., finally found that I had forgot to plug the electronic distributor wire into the harness. Fired right up!
THEN....was falling on it's face/low power; idled great. I had checked the timing (10deg BTDC) or so I thought. Truck runs a whole lot better when you don't have the timing at 10deg AFTER top-dead-center.
Sometimes you have to put aside all of your "experience" and and not "over-think" things when trouble-shooting.
Yeah... I tend to overthink things quite often! I've gotten much better at avoiding those headaches.
motormikeyman
- Year and Model: 2004 XC70 AWD
- Been thanked: 8 times
Replaced my drivers side CV shaft, wheel bearing, brake rotor and brake pads no problemo. Put it all back together nicely. Picked up the tire to put it back on the car and found the dust shield the goes BEHIND the rotor laying under it.... gahhh!
'94 940 wagon, 220K miles- sold to a guy who then drove it to Oklahoma
'99 XC70 AWD, 210K miles- trans went
'04 XC70 AWD, 196K miles- still going strong
'06 S40 sedan, 150K miles- went with the ex
- Been thanked: 4064 times
You can clip the thin bit with tin snips and reinstall that without redoing all the workmotormikeyman wrote: 28 Oct 2021, 11:56 Replaced my drivers side CV shaft, wheel bearing, brake rotor and brake pads no problemo. Put it all back together nicely. Picked up the tire to put it back on the car and found the dust shield the goes BEHIND the rotor laying under it.... gahhh!
This step is ISO approved by Volvo management..
- 9DB0E946-3826-4959-92D2-EB71A3C19600.jpeg (27.15 KiB) Viewed 8790 times
Actual photo from the development of the 240.abscate wrote: 29 Oct 2021, 02:06You can clip the thin bit with tin snips and reinstall that without redoing all the workmotormikeyman wrote: 28 Oct 2021, 11:56 Replaced my drivers side CV shaft, wheel bearing, brake rotor and brake pads no problemo. Put it all back together nicely. Picked up the tire to put it back on the car and found the dust shield the goes BEHIND the rotor laying under it.... gahhh!
- Has thanked: 987 times
- Been thanked: 1075 times
I wish to make a record of this elder abuse with the management.
volvolugnuty
volvolugnut wrote: 29 Oct 2021, 10:18I wish to make a record of this elder abuse with the management.
volvolugnuty
- 150 Replies
- 97322 Views
- 12971 Views
- 11 Replies
- 19429 Views
Last post by volvolugnut
- 1218 Views
Last post by matthew1
- 2431 Views
Last post by liamchesley
