[2001 V70 2.4T] Oil leak, intake side, lower engine / oil pan
Has thanked: 1609 times
Been thanked: 4063 times
At least that banjo is relatively simply. Great shot, except I can feel the back strain through the photo..
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
The TARDIS is back on the road! Got everything put back together last night. No oil or coolant leaks that I can detect so far, but I'll keep an eye on it. No vacuum leaks that I can detect. The rewired ECT sensor is sending a good signal and valid readings according to OBD diagnostics. Everything in the engine bay looks and sounds good, driving is good and peppy, so I'm happy.
A few lessons I learned:
- Always use new washers/bolts whenever Volvo recommends it.
- Always use proper Oetiker hose clamps where Volvo recommends it.
- Genuine Volvo PCV hoses are nice, soft rubber. Don't use an OEM/aftermarket hose that feels more solid.
- For hoses that use reusable worm clamps, pay close attention to the positioning of the clamp and screw head whenever you reinstall it. Make sure you reinstall it in a position that's as easy to reach as possible. This can mean a huge time savings for future work.
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
prwood
Post by prwood »
P.S. I rented my wife a Chevy Traverse 2018 Premier trim edition to use for the week while I was working on the Volvo. That thing is huge and the technology inside is crazy. She loved driving it. I didn't drive it but rode in it once and it was quite nice inside. She was a bit sad to return it and go back to the '01 Volvo, but grateful that I was able to get the work done myself.
Here's a photo of our rental parked in front of an XC90.
Cars I've owned:
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
Hi PRW. Glad you found that oil leak and got her on the road again.
When that elbow hose was leaking did it throw any codes? I'm tracing down the ECM-121B code
viewtopic.php?f=9&t=87435
The only loose hose I have found is that PCV elbow hose to the block. Mine is leaking oil but not as bad as yours. The clamp isn't crimped down tight enough. Before taking off the intake manifold I may try to replace that loose clamp with a SS fuel injector style clamp.
prwood
Post by prwood »
Nope, this didn’t cause any codes, just an oil leak.
Cars I've owned:
