Has thanked: 1505 times
Been thanked: 3818 times
Engineered sushi Deutschland, Hecho in Mexico
bmdubya1198 wrote: 30 Sep 2021, 19:12 I average around 17.5 MPG in my R unloaded...
Ooof, at least you get a big gRin when you dRive it
:D
RaceBeetle gets a stingy 30-32 mpg depending on how much I spin the Garrett….
I scorched the paint of a Porsche on Route 8 yesterday. Only three places to pass in 17 miles so you need road knowledge as well as HP. He came slow into the curve just before the second pass option, so I dropped into third and spooled the Garrett, and whipped by him with a good 20 mph delta. I heard him tread on it but he had a slusher and just spun oil.
He then Hung on my tail until Colebrook, scowling the whole time, blew by me at Winsted and got caught by CT Smokey speed trap that is there like clockwork.
I waved and went beep beep when I went by !
8)
Trip report here!
viewtopic.php?f=38&t=98357
850 LPT wrote: 01 Oct 2021, 12:24 Finished installing all new rear brakes including rebuilt Centric calipers on the 850. I had to fabricate a new line from the hub to the caliper because the old fittings were frozen solid to the tubing. Weeks of spraying penetrating oil on the fittings did nothing.
I also successfully installed a new Bosch front O2 sensor.
On the test drive a serious rattle emerged from the rear. Suspecting busted shock mounts.
Dirk
Check the shock cub bolt under the shock mount. They get loose and sound horrible. Thread here
viewtopic.php?f=1&t=85762
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
scot850 wrote: 01 Oct 2021, 17:27 Well that sucks Dirk. Hopefully a relatively simple fix.
Thanks, Neil. It's usually a pretty straightforward job...if the shock mount bolts aren't too heavily corroded :shock:
I will know by next Saturday.
Tomorrow I will be busy picking up my new ride with abscate, a 92' Volvo 240 sedan. :D
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Has thanked: 1850 times
Been thanked: 1712 times
Good luck with the 240! I have had several and my parents had one for many years as well as 145's. I have a fondness for them as solid dependable cars. Also liked my 940 Turbo which is still one of my all time favourites.
Just don't let Abscate lead you astray!
Firefox for all the pain, I love the car when it is working. Some of the issues are the lack of use especially over the last couple of years. The other one was the groaning suspension that even had the dealer scratching their heads. Eventually found the sub-frame bushes were worn and one was actually loose. Now it runs nice and quiet.
The later models are a challenge in their own ways with expensive 3 stage shocks and troublesome electrics. But when running are great. They are highly strung cars but satisfying when running.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
850 LPT wrote: 02 Oct 2021, 07:50 Thanks, Neil. It's usually a pretty straightforward job...if the shock mount bolts aren't too heavily corroded :shock:
Oooh, have fun with that! 240s are awesome cars. Once I sort out some other projects, I'll get started on mine that's been sitting in the corner of the driveway for the past year plus. Ahead of it is an M50 swap on my E30 and a manual swap on my E39.
abscate wrote: 02 Oct 2021, 03:10
:D
8)
Trip report here!
You've got something on your head there!
I was thoroughly enjoying it last night with the nice cool, dry fall air! It's incredible the difference in power from mid-60s to the daytime temps in the 80s. The car is just so much more lively. Even sounds more aggressive.
That expensive Beetle didn't know what he was dealing with! They gotta watch out for the Race Beetles.
expensive Beetle
When I was looking for a convertible back in 2002 I was down to Benz and Volvo for a convertible with rollover protection.
The Volvo dealer kept trying to sell me a c70 slush box, not a stick to be found
bmdubya1198
abscate wrote: 02 Oct 2021, 12:45
expensive Beetle
For a C70, I'd need HPT manual. No slushbox for me in one of those.
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
IDK, not even a stick would get me into a C70 ...
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
bmdubya1198
erikv11 wrote: 02 Oct 2021, 18:35 IDK, not even a stick would get me into a C70 ...
After driving one, I'm not crazy about the overall feel. They're noticeably heavier than the sedan and wagon.
