Replaced to 33290d:vtl wrote: 26 Apr 2021, 04:50 K-Line TX to TX3 (pin 14).
Also this chip is obsolete (out of production), you may want to replace it with mc33290d.
Vida CEM swapping
MaxDenisov
- Year and Model: XC90 2010
- Has thanked: 2 times
- Vcc-11.png (44.76 KiB) Viewed 1290 times
- VCC-22 (3).png (62.77 KiB) Viewed 1288 times
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
We have learned over time that the schematic needs relatively a lot of power. A few folks were failing cracking the PIN until they provided a better power source and/or used thicker wires. I think you may want to do something about ground and power on your PCB. I use 24AWG (d=0.5 mm) copper wires from CAT5e cable.
Also T5Luke claims the buses are already terminated in other modules, so resistors are not required in OBD-II case. I can't attest to that, maybe leave them not soldered? Or have jumpers like on many Arduino CAN-bus shields.
- RickHaleParker
- Been thanked: 978 times
Thinking of making some heavy Solderless breadboard U-shape jumpers out of plastic coated paper clips. Tedious work but works great when done. Did this decades ago. Wish I had kept track of them.vtl wrote: 26 Apr 2021, 06:48 We have learned over time that the schematic needs relatively a lot of power. A few folks were failing cracking the PIN until they provided a better power source and/or used thicker wires. I think you may want to do something about ground and power on your PCB. I use 24AWG (d=0.5 mm) copper wires from CAT5e cable.
Look for a chip resistor marked 121. 12 X10^1 Ω = 120 Ω . Electrically, It will be across the CANH and CANL outputs.Also T5Luke claims the buses are already terminated in other modules, so resistors are not required in OBD-II case. I can't attest to that, maybe leave them not soldered? Or have jumpers like on many Arduino CAN-bus shields.
Active
Past
Past
vtl
Yes, the point is it might be not needed for OBD case, since the buses are already terminated in other modules. Extra resistor only weakens the signal and makes fronts less sharp.RickHaleParker wrote: 26 Apr 2021, 07:33 Look for a chip resistor marked 121. 12 X10^1 Ω = 120 Ω . Electrically, It will be across the CANH and CANL outputs.
- RickHaleParker
Why not go ahead and do K-line RX to RX3 ( Pin 15 ) for future projects.
Active
Past
Past
vtl
This will be our paid feature unlockRickHaleParker wrote: 26 Apr 2021, 07:51 Why not go ahead and do K-line RX to RX3 ( Pin 15 ) for future projects.
Yeah, makes sense.
- RickHaleParker
You talking modules, ready made circuits on a PCB, or chips with a internal termination resistor? You need 120 Ω at each end of the physical CAN bus. One end of the physical CAN BUS is the CAN transceiver,vtl wrote: 26 Apr 2021, 07:35Yes, the point is it might be not needed for OBD case, since the buses are already terminated in other modules. Extra resistor only weakens the signal and makes fronts less sharp.RickHaleParker wrote: 26 Apr 2021, 07:33 Look for a chip resistor marked 121. 12 X10^1 Ω = 120 Ω . Electrically, It will be across the CANH and CANL outputs.
Active
Past
Past
vtl
CAN-bus has to be terminated on both ends: at CEM and the farthest module (the one having the longest wiring to CEM). Now:RickHaleParker wrote: 26 Apr 2021, 08:07 You talking modules, ready made circuits on a PCB, or chips with a internal termination resistor?
1. If OBD plugs in into real CAN-bus - OBD device does not need termination.
2. If CEM has a dedicated CAN controller just for OBD - it needs termination.
I always thought 2 is the case (CEM has a controller just for OBD), but T5Luke thinks differently.
- RickHaleParker
The CEM has more then one CAN bus port.vtl wrote: 26 Apr 2021, 08:11CAN-bus has to be terminated on both ends: at CEM and the farthest module (the one having the longest wiring to CEM). Now:RickHaleParker wrote: 26 Apr 2021, 08:07 You talking modules, ready made circuits on a PCB, or chips with a internal termination resistor?
The OBD2 diagnostic connector is a separate physical CAN bus. The only two things on this specific CAN bus is the OBD2 diagnostic connector and a CAN bus port on the CEM. I posted the schematic showing this on a previous page. It shows the same thing in VIDA when you look at the network configuration under diagnostics.
The OBD2 connector has no termination resistor because it is not at the of the CAN bus. The diagnostic interface is the end of the physical CAN bus.
The reason they are at the end of physical CAN bus is because they are there to absorb reflected signals.
Active
Past
Past
- RickHaleParker
CT = Communication Tool.
Active
Past
Past
- 8994 Views
Last post by RickHaleParker
- 8825 Views
- 27 Replies
- 27658 Views
Last post by cn90
- 10231 Views
Last post by jonesg
- 5438 Views
