Has thanked: 1497 times
Been thanked: 3810 times
It’s the rag snake.
Just made it to Long Island. Unfortunately I’m driving into the snow, ALB will likely get none.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Well I bought another car unexpectedly. It's nice to have a redblock back again!
volvolugnut wrote: 27 Jan 2022, 17:00
That first looked like a snake skin. But then I hate finding snakes.
Yeah, looks to be a rag snake!
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
I was saved by a lizard. After doing some yard work this lizard ran pass me and was going to enter the garage because of the gaps at both ends from the uneven concrete. It stopped short of going in? I opened the garage door and it still didn't move. Upon moving closer I see the snake in the garage had gone under the gap and bit the lizard so it just froze there. I picked up a shovel then decided with the oval head if I miss it's going to be in the garage for sometime. Switched to a hoe and got it on my first try. The little lizard got away safely.
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Post by FireFox31 »
Sveedy wrote: 27 Jan 2022, 16:31 Stripped off the remainder of some old yellowed clear coat on the fuel rail cover, and took the buffering wheel to the spark plug cover bolts.
What product and cleaning method did you use to clean the fuel rail cover? Mine is a little gross and I was wondering why simple degreaser didn't clean it.
My spark plug cover ("cam cover"?) bolts are dirty and the ones on Geronimo are nearly unusable from dirt in their Torx hole. I'd like to soak them in cleaner to remove all their dirt and oil (from oil filler gasket leaks). Would Simple Green do the job?
FireFox31
bmdubya1198
Simple Green is pretty mild, but I’ve found that it works pretty well. My go-to degreaser is Oil Eater. You might need a stronger solvent to strip that though.
MoVolvos
Post by MoVolvos »
Keep in mind simple green is not good for aluminum but the Oil Eater is fine besides being USDA approved. I would try the Magic Eraser as it is cheap and the generic pads are even cheaper.
Oil Eater Cleaner 5 Gallon
https://www.costco.com/CatalogSearch?de ... =oil+eater
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
I'd just use some de-greaser for the bolts. Or brake clean. I just got carried away with the buffing.
The clear coat on the fuel rail cover was stubborn. I used a paint/ varnish stripper and let it sit for a couple of hours. That loosened it up enough for me to then clean it in the sink with dish soap.
1999 V70 GLT
bmdubya1198
MoVolvos wrote: 27 Jan 2022, 23:07 *
Does Simple Green also use sodium hydroxide? I know that's an ingredient in Purple Power and a LOT of other degreasers, which is why I avoid it.
Sveedy
Post by Sveedy »
^ Is it the sodium hydroxide that is hard on aluminum ?
1999 V70 GLT
Sveedy
Post by Sveedy »
1999 V70 GLT
