- Has thanked: 1614 times
- Been thanked: 4078 times
Its America - you can buy a car with money collected from turning in cans and bottles, if you drink enough.
- Has thanked: 317 times
- Been thanked: 531 times
Just a few thousand bottles is all you need. Some people around here that can do that in a weekend!abscate wrote: 11 Apr 2018, 07:52 Its America - you can buy a car with money collected from turning in cans and bottles, if you drink enough.
Got my cam sensor swapped out yesterday. Car still hiccups. Time to go bang my head against a wall...
sventastic
- Year and Model: 1996 854R
- Been thanked: 6 times
Got the M56H flywheel resurfaced. I love me a nice freshly machined surface...
1996 854R | M56H | 16T | 274k | BC, Canada
Nice. Do you lightly oil that after machining to prevent rust?
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Or put it in a bag with some desiccant packs (Rice or some damp-rid)
Current Volvos:
- FLXC90
Finally spent 15 minutes and reinstalled the passenger under dash panel whose tabs I epoxied back in January.
Current Volvos:
sventastic
I wasn't planning on it, it should be on the car in 2 weeks from now, so if any surface rust builds up I should be able to tackle it with some brake clean and a scotch brite at worst.
Not a bad idea!FLXC90 wrote: 13 Apr 2018, 16:01 Or put it in a bag with some desiccant packs (Rice or some damp-rid)
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Slayed the CCM-236 Recirc signal too low today. Removed motor, cleaned the grease out of the electrical potentiometer/varistor contacts, lubed the shaft with disc brake grease and reinstalled. Got the error again. Disassembled and moved the motor exactly one tooth out of position towards the opposite direction. Works great. During initial reassembly everything was in the exact position it didn't work at previously. So if you're stuck, try moving that sucker one tooth clockwise. Position of the shaft doesn't seem to matter provided for the most part it is in the middle of the slide area. Let it go to full recirc (I think it was this position) then install the linkage with it pulled tight. Then reinstall glove box support beam and glovebox. Sit back and enjoy your ability to no longer have to smell the outside or inside.
Used VIDA to determine the ECC's perceived motor position. Get a nice clean swipe now.
Note to a specific moderator: no seats were lubed in the repairing of this item or the making of this message. =p
2023 Lexus RZ450e -66k
I’ll be right over when the power fails
- wizechatmgr
You're a day early.
